Go Back   Detailing World > Lifestyle > The Tech & Gadget Zone
The Tech & Gadget Zone Gadgety, Techy or even a Techy Gadget! Stick a post in here! Sponsored by SlimsDetailing - inspired by anybody who has a car they love and care for
Old 05-02-2018, 04:34 PM   #1
mt8
Bt and sky through one tv?
I have a sky box and a bt tv box, is it possible to connect both up to 1 tv?
It is an old tv but has 2 hdmi slots available if that helps.
Cheers.
mt8 is offline   Reply With Quote
Old 05-02-2018, 04:56 PM   #2
Don’t know how the Sky box connects to the TV, but the BT box is connected to a HDMI slot and the aerial is run through it to the TV.
If the Sky box is connected just via HDMI, then cannot see why you can’t connect both as you’ve 2 slots...
Old 05-02-2018, 05:06 PM   #3
staffordian
staffordian's Avatar
I'd be very suprised if you had a problem doing this.
I think both boxes would connect using an HDMI cable. The only issue I forsee is that you might need to use the input selection on the remote control to switch to your box of choice rather than it happen automatically, depending on the age and sophistication of your television.
staffordian is offline   Reply With Quote
Old 05-02-2018, 06:52 PM   #4
DrEskimo
DrEskimo's Avatar
I think the boxes to HDMI would be fine. As above, just switch the input to whatever input you want.
However, I have my Sky box connected to the satalite and need two satallite cables to do this. Does the BT box also require connection to the satalite?
Old 05-02-2018, 06:58 PM   #5
mt8
No it’s just connected via the aerial, just unsure of whether there will be any interference or issues with them both powered up and viewing/ recording.
Will power them both up tomorrow and see if there any issues, fingers crossed
Old 05-02-2018, 07:26 PM   #6
Philb1965
Shouldn't be any problems with each box on an hdmi port.
Philb1965 is offline   Reply With Quote
Old 06-02-2018, 11:41 PM   #7
mt8
As suggested, no issues and both boxes working okay on seperate hdmi ports.
just need to remember that which ever box im watching i need to switch the other one off as the sound carries over, probably due to having no optical input on the tv for the sound bar so had to hook it up directly to the bt tv box.
Luckily when i switch on the boxes from standby the tv recognises the input and switches it automatically.
The Following User Says Thank You to mt8 For This Useful Post:
staffordian (07-02-2018)
