Old 13-09-2017, 07:15 PM   #1
renton
Getting the best from Scholl S40
I've bought a bottle of s40 to replace my megs 205 and was wondering what's the best way to use it to get the best finish from it.
I'm using a das6 and have also bought the recommended scholl orange pad.
Any hints and tips please.
renton is offline   Reply With Quote
Old 13-09-2017, 09:44 PM   #2
renton
Anyone ?
Old 13-09-2017, 09:53 PM   #3
Sawel
Scholl's range of polishes are pretty straightforward to work. S40 is quite oily so you can work it for longer but you only need to use small amounts of S40 on the orange pad, work it on speed 5 with moderate pressure for 60 - 90 seconds at most with arm movements of 1 - 2 inches per second covering an 18 inch x 18 inch area. Make sure to do several passes over the same area. Then use no pressure at all for 45 - 60 seconds for a couple of passes.
You will notice the polish has been worked properly as it will turn very clear. Wipe off and job done.
The Following User Says Thank You to Sawel For This Useful Post:
renton (14-09-2017)
Old 13-09-2017, 09:58 PM   #4
Not to sure about the orange pad, but Scholl S40 is a fantastic finishing polish and leaves a stunning finish works on all paints but you only need to use very little of it, 2-3 small drops and at speed 3-4 that's how I use it
Only use the wait of your machine and it can be worked for as long as you want but can be a bit fiddly to remove if you haven't worked it right, but most Scholl polishes are like that anyway. Apparently it's supposed to enhance the colour on dark paints but I've never noticed the difference between my other finishing polishes I've used in the past you will like it
The Following 2 Users Say Thank You to chongo For This Useful Post:
renton (14-09-2017), Soapybubbles (27-09-2017)
Old 14-09-2017, 08:59 AM   #5
LewisChadwick7
LewisChadwick7's Avatar
what pad do you go for with S40 chongo?
Old 27-09-2017, 08:40 PM   #6
Manny4pacman
Manny4pacman's Avatar
I used the yellow spider neo pad and dam so easy on use awesome finish .
Beware remove residu after every hit or at least a panel .... Wipe off i would give it 3/5 stars ....Some QD or Prep spray is handy =)
Here al list of there products and there recommend pads om the picture
https://www.schollconcepts.com/en/pr...bing-compounds
Normally i use buff and shine pads but i see me grabbing more and more to the scholl Pads
I have S3XXL S20 S30 S40 and they al have there propose .... if the S 30 runs out then i keep it whit the 3 others
Manny4pacman is offline   Reply With Quote
Old 27-09-2017, 09:13 PM   #7
It depends on what paint am on, usually a yellow Rupes polishing pad on soft paint and the black finishing hex pad or L/C HT crimson pad on medium to hard paints
The HT crimson pad I used yesterday with S40 and the results where epic S40 has a fantastic working time, just keeps on going and going.
