#1 |
Best wash procedure after ceramic coating
I'm having the ceramic coating put on this week by a prof detailer, what products do I need to buy to maintain? Thinking foam for pre wash, or should I use some kind of citrus wash instead? Bathe or bathe + and finish with wet coat I assume..
Any advice greatly appreciated |
#2 | |
I wash with carpro reset, maintain with reload and hydro2 Sent from my iPad using Tapatalk Pro |
The Following User Says Thank You to LeeH For This Useful Post: | mojo555 (15-10-2017) |
#4 |
Is cure necessary? Only ask as this sounds like the weak point to add swirls afterwards? Less contact with paint the better?
#5 |
I use bathe+ weekly and cure every couple of months. I didn’t like the gyeon snow foam as dilution rates made it expensive and it wasn’t particularly thick. I am currently using odk arctic as a snow foam.
The Following User Says Thank You to Chamment For This Useful Post: | mojo555 (15-10-2017) |
#6 |
DW Sponsor
mojo555 - Cure is so slick, it will rather prevent swirl marks. You might use it also on a wet car as a drying aid and QD in one.
The Following User Says Thank You to Gyeon Jeremy For This Useful Post: | mojo555 (15-10-2017) |
#7 |
Normal snow foam for regular wash and a citrus pre wash every month or 2.
I use Gyeon Bathe +, drying is real easy, i use a metro vac blow dryer then Cure after. Providing you have a suitable clean microfibre no swirls should be inflicted using Cure. |
The Following User Says Thank You to gibbo555 For This Useful Post: | mojo555 (15-10-2017) |
#8 |
Sorry to re-open an old thread, but I was wondering if anyone could help me.
I had MOHS+ applied 2 weeks ago, and this weekend will be the first wash. I have been recommended to use Bathe+ and Cure after, but I was wondering if I could use Wet Coat instead of Cure, as I have heard it is easier to apply? Could I ask, what is the difference between the two products, and are there any videos demonstrating how to apply/use them, sorry I am a total novice to the car cleaning world, always took my car to a hand car wash previously, but since having the new one and having it ceramic coated, I really want to learn how to wash the car correctly? Sorry also forgot to add, I have a matt black foil wrapped roof, what products should I use on that? Many thanks Last edited by Bigblew; 24-01-2018 at 07:55 AM. |
#9 |
Hi Jeremy,
I am sorry to bother you, but is there any chance you could help with my previous post, I would really appreciate your help as I am a complete novice at this sort of thing? Many thanks |
#10 |
With the coating being so fresh I would use plain bathe, and not bathe+ or any thing that will top it up or leave anything behind, as they simply won't perform as well as Mohs. After a few months or when water behaviour starts to slow down then sure top it up a little. But I think you'll find a bare shampoo and drying will see gloss and water behaviour impress you.
The Following User Says Thank You to Yellow Dave For This Useful Post: | garycha (28-03-2018) |
Thread Tools | |
Display Modes | |
