Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Gyeon
Old 29-01-2018, 07:29 PM   #11
Gyeon Jeremy
DW Sponsor
Gyeon Jeremy's Avatar
Bigblew - the difference between Q清 WetCoat and Q清 Cure is pretty huge and they have other functions as well.
Q清 WetCoat is only a hydrophobicity booster. It's not a protective product and it will give you the biggest benefits then the coating start becoming contaminated or will simply need a repellency boost.
Q清 Cure is the real maintenance spray for coated cars, as it contains silica and works as a ceramic detailer/spray sealant.
It's much more effective in prolonging the real durability of the protection a coating provides and helps to maintain the self cleaning abilities in tact.
My personal favourite combo in currently Q清 Bathe Essence, Q清 Cure, Q清 Smoothie and the Q清 SilkDryer towel. These are the basics and tbh all that you need to take care of your coated car in a safe and effective way...
Gyeon Jeremy is offline   Reply With Quote
Old 29-01-2018, 07:52 PM   #12
Bigblew
So is Bathe Essence a new product then, my detailer didn’t mention that one.
His aftercare schedule listed Bathe+ then Cure.
I do need to tell you though, that I have PPF on the front of the car and MOHS+ everywhere else, would you still recommend Bathe Essence and Cure now? He did apply the Cure product on the PPF as well to give my car the hydrophobicity everywhere, so really I need products that work on it all?
Also, to make matters even more complicated, I have a matte foil roof, which was fitted at the factory, but I don’t want to put any sort of sheen on that, so what would you recommend to use on that?
Sorry to ask so many questions, but I truly have no clue.
I intend to use Gyeon Foam to start with as well, does that fit in well?
Sorry!
Bigblew is offline   Reply With Quote
Old 29-01-2018, 09:18 PM   #13
Commander2874
I had my car coated back in october. I use bathe+ and 2bm and towel touch dry. I use reload to keep coating topped up every 3 months. Use a decent mf plush towels.
For foam i use Bilt Hamber auto foam. It's brilliant.
Sent from my SM-N910F using Tapatalk
Commander2874 is offline   Reply With Quote
Old 29-01-2018, 10:53 PM   #14
Eric the Red
Surely the pro detailer who applies it will explain how to maintain the coating,it would be in his best interest to have you as a returning customer or for you to recommend him to other potential customers
Eric the Red is offline   Reply With Quote
Old 30-01-2018, 07:32 AM   #15
Bigblew
He did give me an after care sheet, he was very good:
'*Please do not wash the vehicle for one week after coating application and SH PPF installation, to allow the coatings to fully cure and the film to adhere and edges to settle fully*
Aftercare Routine for Gyeon Coatings and Suntek Self Healing Paint Protection Film:
Paintwork Care procedure:
Ideally the vehicle should be snow foamed (using a foam lance, attached to a pressure washer – we recommend Gyeon Foam) to remove any surface dirt, ahead of making physical contact with the paint. To wash the vehicle, we recommend a high quality lambswool wash mitt (again, Gyeon make one) and the Gyeon Bathe+ Shampoo, which is made to be 100% compatible with the surface coatings applied to the vehicle. Use the wash mitt along with shampoo in a bucket of (ideally) warm water, and gently remove the remaining dirt from the surface. Follow this with a rinse to remove any suds from the shampoo, then carefully dry the surface with a dedicated drying towel (we recommend the Gyeon Silk Drying Towels). This should largely leave the car clean. It is worth investing in some Quick Detail (Gyeon Cure) which is applied maybe every 2-3 washes, or as required to add slickness and gloss to the surface, and again is compatible with the coating system. This can also be used to remove any smears or water marks following the drying process, and for area such as door shuts.
You can also, if you choose to, wax the car. This may reduce the hydrophobic effect on the car (as the wax become the new top layer of protection) but the underlying Gyeon Coating will remain.
Over time, the vehicle will collect contamination on its surface. The main types of contamination tend to be tar deposits (small black deposits), fallout (orange in colour) or tree sap. These can be safely removed, as and when required, using the corresponding Gyeon products – Tar, Q2M Iron and Clay products. If unsure, then please consult a professional Detailer (we are happy to advise as and when required, over the phone or via Email)
All of the above can also be applied to the wheels. However, depending on how corrosive the brake dust is on your particular vehicle, you may get ‘brake dust pitting’ occurring in the corners of your spokes, if your vehicle hasn’t been washed for an extended period. Please do not scrub away at these deposits (brown/orange in colour), instead using Gyeon Q2M Iron to safely dissolve these deposits, and simply rinse away.
Tyres and Exhausts should be dressed and polished with respective products.
Glass Protection will last roughly 12 months, but this is mileage dependent – maybe 15,000 miles. This can then be retreated very easily.
Interior protection is approx. 18 months. You will note that any water will not penetrate the mats and will instead sit on top of the surface. Simply soak this excess up if required. If Chewing Gum comes into contact with the mats, then this should remove more easily than untreated mats. However, is residue remains, apply something frozen to these areas, then it will ‘break up’ when tackled.
Paint Protection Film – Care Procedure
Suntek Paint Protection Film incorporates a ‘Self Healing’ top coat which relevels when a heat source is applied (boiling water, heat gun, or the Sun). Most scratches (as severe as a scouring pad!), swirl marks and such will simply disappear when heat is applied.
Otherwise, when washing take care to not apply undue focus of a pressure washer to the edges of a film (where not wrapped) and wash towards the edges when using a wash mitt. There should never be a problem with any edges, so there isn’t a need to be overly cautious, but it’s best to apply best practice from a care perspective.
Usual wash and care guidance is in line with the paint procedure detailed above. The film isn’t as ‘slick’ as paintwork (different surface tension) so applying Gyeon Cure after every wash may help in this respect.
Any dead insects should be removed with a 10% IPA mix, then heat applied afterwards for the surface to relevel, should an outline remain.
The film is warrantied against yellowing, cracking and various other defects (warranty form to follow) and we warranty our installation for 10 years so you are not only covered against defective film, but also any installation issues. Please contact us if a problem arises and we will address as a priority.'
But after coming on here, and seeing what other people have used, its always good to get some good advice, and when you have someone like Gyeon Jeremy to offer advice, you need to take advantage of that.
Old 30-01-2018, 08:59 AM   #16
Eric the Red
My reply was to the original post, but you are right being on here you will get good advice
Old 30-01-2018, 01:59 PM   #17
Bigblew
My apologies, I wasn't sure which post you was replying to!
Old 31-01-2018, 05:14 PM   #18
Gyeon Jeremy
DW Sponsor
Bigblew - you've got professional advise from your detailer - something you might follow without hesitation.
You're on the biggest detailing forum in the universe here and I guess each and every user will have his own preference. Wanting to follow each tip would make you buy a ton of products.
I guess you should keep things simple. Take the safety of the wash routine as priority.
Start with a ph-neutral snow foam. Leave it to dwell and rinse.
Use the 2 bucket method. No matter which shampoo you choose, it should be safe and slick. Both Bathe+ and Bathe Essence are like that. I love the concentration of Bathe Essence and the superb slickness, so that would be my choice. However, feel free to use Bathe+ if you already got it!
Try your car with a soft, high quality towel.
Use Cure over every surface you wish. Although we have Cure Matte designed for matte finished surfaces, if you proceed with a low amount of the regular one, you can easily use it over paint, matte vinyl and PPF as well.
Old 31-01-2018, 07:39 PM   #19
Bigblew
Thanks guys, really appreciate the help.
Decided I am going to with Gyeon Foam, Bathe Essence and the Cure.
Add the buckets, snow foam lance, drying towels, wheel brushes, cloths for applying Cure etc. etc, this is going to get expensive!
The Following User Says Thank You to Bigblew For This Useful Post:
Gyeon Jeremy (01-02-2018)
Old 02-02-2018, 07:09 PM   #20
matt525d
Worth investing in a citrus pre wash this time of year. Foam is crap for heavy dirt and it won’t remove it, so you’ll end up inflicting damage into the coatings
So follow Jeremy’s wash procedure but rinse the car first to get as much off as possible, then a citrus pre wash via a lance or pump sprayer. Plenty of good ones around which unfortunately Gyeon do not make as of yet.
After letting that dwell, rinse off and foam to get any last bits off. Then bucket wash and dry. I do this to all coated cars and the prewash is paramount in the maintenance of it
If you see water being held in high traffic areas ie lower doors a simple hit it with iron fallout remover will sort it as the coatings do get clogged
Hope this helps
matt525d is offline   Reply With Quote
