Old 22-02-2017, 09:43 PM   #1
SKY
SKY's Avatar
Location: The Democratic People's Republic Of South East Essex
Removing green algae from seals
Have purchased a 2010 mondeo for tugging our new caravan.
Around the glass seals and by the boot hinges three is a lot of green algae staining.
What's the best thing to remove this ?
SKY is offline   Reply With Quote
Old 22-02-2017, 09:45 PM   #2
First port of call for me would be strong APC (I'd hit it with 25% Surfex) and a detailing brush.
Old 22-02-2017, 09:54 PM   #3
Darlofan
APC then power wash it.
Darlofan is offline   Reply With Quote
Old 22-02-2017, 10:00 PM   #4
To be honest hitting it with a strong APC like Surfex could damage the seals, so use a weak solution of APC first and let it soak in, then with a soft detailing brush just work it in then get a damp MF towel to wipe away the dirt.
Old 22-02-2017, 10:01 PM   #5
Sk8ir
Sk8ir's Avatar
On my dad's car which had been stood a long time there was quite a bit of moss/algae on the seals. As recommended above a good soak in APC, then agitate with a brush, then a good blast with the pressure washer, got rid of all the surface stuff.
There was still a bit of marking/staining on the rubber, so I sprayed it with a Hydrogen Peroxide solution, this made a big difference, and also helps prevent future regrowth by killing off any spores. Then rinsed and treated with GummiPflege... looked as good as new.
Sk8ir is offline   Reply With Quote
The Following User Says Thank You to Sk8ir For This Useful Post:
steelghost (22-02-2017)
Old 22-02-2017, 10:03 PM   #6
Ads_ClioV6
Ads_ClioV6's Avatar
Britemax grime out i have used without causing any issues
Ads_ClioV6 is offline   Reply With Quote
Old 22-02-2017, 10:06 PM   #7
On a modern car, these would be butyl rubber, which I don't believe would take any harm from some APC for 5 minutes. 10% would probably work as well.
Old 22-02-2017, 10:15 PM   #8
66Rob
66Rob's Avatar
I have used Meg's APC for this agitated with a soft brush. Don't use neat though (even the retail version is very strong) as can mark trim which is then a pain to put right I ended up using at about 20% and that was about right.
Don't let it sit on the trim for too long.
Old 22-02-2017, 10:29 PM   #9
Zebra
Old toothbrush and car shampoo should remove it.
Old 22-02-2017, 10:52 PM   #10
Robbi Hong Kong
Robbi Hong Kong's Avatar
its a living organism so you MUST kill it or it will return....I've done a few vehicles with the same problem...use the following: Use a steamer to go over the whole area...the steam will kill it then brush on some Biobrisk with a detailing brush...Kaboom....green algae banished forever.
Robbi Hong Kong is offline   Reply With Quote
The Following User Says Thank You to Robbi Hong Kong For This Useful Post:
slim_boy_fat (23-02-2017)
