Old 11-12-2011, 10:46 AM   #61
RSPSTEVE
1293 A+ Block with fresh rebore
Turbo Crank Lightened and Balanced
Standard Conrods Lightened and Balanced
New Turbo Pistons with 14cc Dish
New Morspeed 11 stud Turbo Head with 29cc Chambers
New ARP bolts used in Head and Conrods
New Phase 2 Avonbar Camshaft and Heat Treated Followers
New Alloy Vernier Pulleys, duplex chain and new tensioner
Lightened Flywheel
New Grey Diaphragm
New Paddle Clutch plate
New clutch master cylinder, new slave cylinder, new clutch arm and braided hose
New release bearing
New Straight Cut Gearbox, using a clubman gear set
New Timken Roller Bearing Straight Cut Drops
New Kad Internal Gear Linkage and Quickshift
New front mounted 10 Row Oil cooler
New KAD adjustable oil pressure regulator
T3 Turbo
Braided turbo oil feed
New Avonbar 12psi Actuator
New Avonbar Dump valve
Benross Machined Exhaust Elbow and Manifold
New Metro Turbo Downpipe, fitted with Lambda sensor
New Maniflow 2 inch Turbo Exhaust.
Rebuilt Turbo Carb, with Needle and spring for 12psi (New from Avonbar)
Large front mounted intercooler, with silicon and stainless steel pipe work
New Nic R Stainless Steel Plenum Chamber
New Fuel Pressure Regulator
New Braided Fuel Pipe throughout.
MPi Fuel Tank
New MPi Fuel Pump and Sender
Fuel Pump wired with inertia cut-out.
New Water pump and fan
New Minispares 2 Core radiator
New KAD top engine Steady
New Avonbar Ultimate Water pump top engine steady
New KAD Lower Gearbox Engine Steady Kit
Denso (Small) alternator
New Stainless steel catch tank.
Crank, timing cover and rocker cover breathers
RSPSTEVE is offline   Reply With Quote
Old 11-12-2011, 10:59 AM   #62
dubber
dubber's Avatar
Excellent, the next best mod for that would have been the front mounted rad
dubber is offline   Reply With Quote
Old 11-12-2011, 11:03 AM   #63
RSPSTEVE
i havnt got many pics of it, but it was made into a mk1 lookalike after those pics , lights bumpers,door hinges,sliding windows, rose petal alloys etc but someone made me an offer on it i couldnt refuse so it went before i could take some pics .
Steve
Old 11-12-2011, 05:37 PM   #64
kemslea
This is my 35th Anniversay model.
kemslea is offline   Reply With Quote
The Following 5 Users Say Thank You to kemslea For This Useful Post:
Big T (19-11-2014), Bratwurst (11-12-2011), jb93 (20-09-2012), Sportspack Mark (11-12-2011), Strothow (15-12-2011)
Old 11-12-2011, 05:41 PM   #65
kemslea
and also the Cooper Sport before the 35th Anniversary
The Following 4 Users Say Thank You to kemslea For This Useful Post:
Bratwurst (11-12-2011), FiestaGirlie (11-12-2011), jb93 (20-09-2012), Sportspack Mark (11-12-2011)
Old 11-12-2011, 05:55 PM   #66
Bratwurst
Bratwurst's Avatar
Location: Paisley - Officially the sexiest town in Britain
^ two absolute belters!
Bratwurst is offline   Reply With Quote
The Following User Says Thank You to Bratwurst For This Useful Post:
kemslea (11-12-2011)
Old 11-12-2011, 05:58 PM   #67
sf1506
Some nice minis here
sf1506 is offline   Reply With Quote
Old 11-12-2011, 08:26 PM   #68
alexjb
alexjb's Avatar
Here's my baby
alexjb is offline   Reply With Quote
Old 11-12-2011, 08:43 PM   #69
Flair
Flair's Avatar
Here's my old S.
Flair is offline   Reply With Quote
Old 11-12-2011, 09:34 PM   #70
Sportspack Mark
Sportspack Mark's Avatar
Attachment 20978
Attachment 20981
Two stunners right there
Sportspack Mark is offline   Reply With Quote
