Old 11-07-2016, 07:58 PM   #191
Filtrum
Had a look at a manual on there for the one I think it is but didn't seem to mention whether it would need pressure from a tap or not. Will just give it a try when I get it. Cheers for the pump recommendation will have a look.
Filtrum is offline   Reply With Quote
Old 22-07-2017, 02:10 PM   #192
michaelb73
How do you guys stop these butts from leaking?
Mine are leaking from the pipework where they are joined.
I still need to add another butt to my 2 existing ones and have bought a pump so I can use my hose pipe.
michaelb73 is offline   Reply With Quote
Old 22-07-2017, 04:51 PM   #193
Make sure you use the rubber washers and tighten then all up properly. You may also need a jubilee clip on the pipe, depending on the fitting.
Old 23-07-2017, 02:18 PM   #194
dabhand
dabhand's Avatar
I've used bathroom sealand. Works OK.
dabhand is offline   Reply With Quote
Old 23-07-2017, 04:11 PM   #195
Bazsm
How do you guys stop these butts from leaking?.
I've connected my butts with hozelock connectors so no leaking on mine
Bazsm is offline   Reply With Quote
Old 23-07-2017, 06:59 PM   #196
michaelb73
Used all the washers along with sealant and jubilee clips.
Still weeping at the joins. ��
Old 23-07-2017, 07:00 PM   #197
Can you post a picture?
Old 24-07-2017, 03:26 PM   #198
ganwilliams
ganwilliams's Avatar
Try getting some PTFE tape to wrap around any threads / joints etc as you are putting the joints together.
ganwilliams is offline   Reply With Quote
Old 12-09-2017, 06:59 PM   #199
gardian
I have been reading this thread for a while and decided to get a setup in the garden. I have a Guttermate diverter with their own fine mesh filter, this goes into a 100 L water butt, this is connected at the top to another 100L butt and this is connected, again at the top, to a 210L butt which is where i am wanting to take a feed for my pressure washer from. I have just been out to get a sample of the water i have collected and the water in the 210 L tank isnt as clear as i though it would be. it had a couple of little floaters in and looked a tiny bit cloudy. what I am doing wrong? would this damage the Karcher i would be using it in, or the paint? seems the filter at the drain pipe and the 2 100 L tanks isnt enough? thanks
gardian is offline   Reply With Quote
The Following User Says Thank You to gardian For This Useful Post:
Bazsm (12-09-2017)
Old 13-09-2017, 12:02 PM   #200
My waterbutts are south facing and in the summer the water gets a little bit warm and slightly green. Doesn't do the car or the pressure washer any harm.
rain, rainwater, recycled, water, water butt
