Old 07-10-2017, 08:04 PM   #1
Chuffy
Chuffy's Avatar
Gyeon Q2M clay - leaving hazing on paint
Used some new gyeon clay on a black A3 today
I made up some lube using demon shine (neat) along with some car shampoo in there too
I had washed the car then used some auto finesse ObliTARate followed by the clay bar
I kept the area wet using little pressure
The car was clean & the bar hardly picked up much
After I gave the car another wash & dried it off there were a lot of panels with hazing
The rear was the worst
I haven’t came across this before. This is my 1st time using this clay
I done a test area in the door sill and it is leaving some hazing behind
Could it be the lube letting the bar bite too much?
Chuffy is offline   Reply With Quote
Old 07-10-2017, 08:12 PM   #2
fatdazza
Most likely clay marring. Can be caused by not enough lube / too much pressure / not keeping clay clean enough / soft paint.
It will show up most on black paints. Clay is abrasive nd it is not always possible to avoid marring. Finishing polish will remove the marring.
fatdazza is online now   Reply With Quote
Old 07-10-2017, 08:15 PM   #3
Chuffy
Chuffy's Avatar
Old 07-10-2017, 10:47 PM   #4
Hereisphilly
Hereisphilly's Avatar
I'd definitely have another go with some dedicated clay lube or onr and see if it makes a difference
Old 08-10-2017, 09:41 AM   #5
Chuffy
Chuffy's Avatar
Will this not make it worse go By over it again?
I only had PB black hole and applied by hand. So you not kicked things back a little
Old 08-10-2017, 09:47 AM   #6
Hereisphilly
Sorry i didn't realise you had done the whole car
Clare marring is often very fine, so something like megs UC by hand should take the worst of them out
Old 08-10-2017, 09:48 AM   #7
stangalang
king of the flexonian
stangalang's Avatar
Clay bars, softish paints and high peel will almost always look like the car has been sanded.
Couple if tips, you can never use too much lube, use only enough pressure to stop the clay from sliding out of your hands (as little as possible), make sure the clay is continuously turned and needed to keep it clean, expect some marring
stangalang is online now   Reply With Quote
Hereisphilly (08-10-2017)
Old 08-10-2017, 10:31 AM   #8
Chuffy
Chuffy's Avatar
Sorry of that reply. Using my phone
Thought I was using plenty of lube. It’s ****ible there was too much pressure
I’ll hit the tailgate with the porter cable and see what it does
Old 08-10-2017, 11:16 AM   #9
Clay marring on black cars especially your colour is pretty much impossible to avoid a finishing polish or a abrasives cleanser polish will remove the marring, but I would advise not to hit your tailgate with your DA
Old 08-10-2017, 12:08 PM   #10
Chuffy
Chuffy's Avatar
Smart @ss
