Old 09-10-2017, 03:30 PM   #21
10% Surfex is perfectly sensible for general cleaning of exteriors (although I tend to up it a bit for tyres). Considerable overkill for Auto Foam though!
Old 09-10-2017, 03:42 PM   #22
nog
Not been on here much but am I right thinking snow foam/lance is not the way to pre wash now and better to use snow foam through a pump sprayer.
Used the lance the other day and whilst it looks impressive didn't seem to move much dirt off the car.
cheers
nog is offline   Reply With Quote
Old 09-10-2017, 04:06 PM   #23
Nidge76
Nidge76's Avatar
Originally Posted by WannaBd View Post
I found surfex to leave white marks sometimes that's why I stopped using it even at what I thought were low dillutions
What sort of dilutions were you using for it to leave white marks?
Nidge76 is offline   Reply With Quote
Old 09-10-2017, 04:07 PM   #24
Nidge76
Nidge76's Avatar
Is that 10% on the paintwork for Surfex? What dilution through a pump sprayer for Auto Foam do you recommend?
Old 09-10-2017, 04:08 PM   #25
ollienoclue
Surfex is a de-greaser, I thought for engine bays and similar?
I would stick to Green-star if I wanted something to put through a pressure sprayer, alter dilution ratio to suit requirements.
Do not let green star dry on anything mind. Wet the car first if it helps or do it in the shade.
I feel BH autofoam is a lot safer in this regard.
ollienoclue is offline   Reply With Quote
Old 09-10-2017, 04:11 PM   #26
Smanderson117
cheers
Pump sprayer tends to be more economical but the cleaning power is largely the same IMO. Depends what foam you use as to how good the cleaning is, for instance, I don't rate the cleaning at all of autobrite magifoam. However Bilt Hamber autofoam seems to leave the car pretty much clean even when it's monging
Smanderson117 is offline   Reply With Quote
The Following User Says Thank You to Smanderson117 For This Useful Post:
nog (10-10-2017)
Old 09-10-2017, 04:15 PM   #27
BH themselves recommend
Dilute as required to obtain a PIR (panel impact ratio) of between 1:100 and 5:100.
ie the liquid actually landing on the vehicle should contain between 1% and 5% Auto Foam. I tend to use it around the 3-4% mark.
For Surfex, yep 10% is fine on paintwork (there is a thread somewhere where BH themselves said that even neat it wouldn't actually do the paint any harm so long as it was washed off properly).
I think that's the key with pretty much anything on paintwork - thorough rinsing. I've seen marks on my paintwork when I was using 5% Surfex to clean door shuts because it didn't get rinsed off properly.
Nidge76 (09-10-2017)
Old 09-10-2017, 04:29 PM   #28
Nidge76
Nidge76's Avatar
Thanks for clarifying that up for me SG and sorry to OP for hijacking thread slightly.
Sent from my F3311 using Tapatalk
Old 09-10-2017, 08:29 PM   #29
Brian1612
Recently used a 4% mix of Autofoam and Surfex on a neglected neighbours car through a pump sprayer. Car was pressure washed prior to the prewash. This was topped with snow foam to prevent the pre wash drying then PW off after a few mins... photos speak for themselves!
Old 09-10-2017, 08:41 PM   #30
Bristle Hound
DW's Biggest Thread Starter & Moderator
Bristle Hound's Avatar
ValetPro Citrus Pre-Wash for me
Surprised it hasn't been mentioned in this thread already ...
Bristle Hound is offline   Reply With Quote
