Old 02-06-2017, 06:41 PM   #21
dellwood33
dellwood33's Avatar
My research so far, tends to suggest that 0 to 10 ppm is the optimum, with any higher figures warranting a change of resin. Anyone used the water at above 10 without spotting ?
dellwood33 is offline   Reply With Quote
Old 02-06-2017, 07:28 PM   #22
Radish293
Radish293's Avatar
Water filter
Been looking all day at options, Race Glaze, Pure Final Rinse, Unger or D Aqua 11l. Still can't decide. Ahhh!
Old 02-06-2017, 08:31 PM   #23
Chris J S
I've recently picked up a 14 Litre race glaze and am very happy with the results. No water spots at all and no flow problems. Have not owned it long enough to comment on how long it will go before the resin needs changing. The larger units are meant to be more efficient, so if I get 1000L+. That's great for me.
Also a shout out to Mark. I called him in the morning and asked him if he could get me a unit in time for me to do a job on the same day. He managed to find me a unit close by that I could go pick up within a couple of hours.
Chris J S is offline   Reply With Quote
The Following 2 Users Say Thank You to Chris J S For This Useful Post:
RaceGlazer (05-06-2017), Radish293 (02-06-2017)
Old 02-02-2018, 10:40 PM   #24
Radish293
Radish293's Avatar
Question. Where is best to connect the DI filter. At the tap then use a hose, hose full of crap water before the pure. Or at the end of the hose and more it around the car as it’s rinsed.
Old 02-02-2018, 11:36 PM   #25
Chris@N
Originally Posted by alex877 View Post
When it comes to water filtration, I decided to install the whole house water filtration system and this resource was pretty helpful https://iwaterpurification.com/best-...-water-filter/ . I wanted to be sure that my appliances like washing machines, blenders, water heaters last longer.
To be fair they’re not as expensive as i had imagined them to be. Do you mind me asking which one you bought and why you chose that one?
Chris@N is offline   Reply With Quote
Old 02-02-2018, 11:44 PM   #26
fatdazza
I have a separate hose on a reel only used for di water. Solves the problem .
Old 03-02-2018, 07:14 AM   #27
LeeH
LeeH's Avatar
I use one of those springy hoses.
Old 09-02-2018, 03:19 PM   #28
Jonny_R
Jonny_R's Avatar
Same.
DI connected where jet wash is at end of hose reel then a coil hose and carry the vessel around with me.
Helps ive only got the 7L RG one so not that heavy to lug about
Jonny_R is offline   Reply With Quote
The Following User Says Thank You to Jonny_R For This Useful Post:
Radish293 (15-04-2018)
Old 09-02-2018, 05:30 PM   #29
RaceGlazer
Approved Trader
RaceGlazer's Avatar
The general principle is to minimise wastage of the filtered water.
So, when I had a 7L unit I had a 5ft hose out of it and carried it round the car with me. I could only ever possibly waste 5ft of purified water. Other end of it ran back to the tap.
Now with the 14L I have mounted up I have a dedicated hose running out to the car wash area from it, about 30ft, but make sure that hose doesn't drain itself. It just change the hose running from my tap to either my PW or the Filter.
Hope that helps
Mark Wibberley
DW Approved Trader since 2009
www.raceglaze.co.uk
www.morethanpolish.com
www.carcovershop.co.uk
The Following User Says Thank You to RaceGlazer For This Useful Post:
