Old 11-02-2018, 03:05 PM   #1
Chris.91
Drying after a snow foam and rinse
Finally got a bit of dry weather (but still very windy). I'm going to snow foam and rinse the car today (no contact wash unfortunately). Should I leave it to dry itself or pat dry it with a drying towel? Don't want to rub any more dirt into it!
Cheers.
Chris.91 is offline   Reply With Quote
Old 11-02-2018, 03:27 PM   #2
crxftyyy
Have you got any drying aids? Personally use AF Aqua Coat and it gives protection as well as helping dry the car
crxftyyy is offline   Reply With Quote
Old 11-02-2018, 03:34 PM   #3
leeandfay
I'm talking personally here but i would rather not bother because you'll either end up with swirls inflicted from drying or water marks and grit infused droplets either way.
If you can't get to the wash stage leave it but as i say this is my opinion on it.
leeandfay is offline   Reply With Quote
The Following User Says Thank You to leeandfay For This Useful Post:
Sicskate (11-02-2018)
Old 11-02-2018, 03:35 PM   #4
Chris.91
I've got Bouncers Done and Dusted QD? Use that while pat/wipe drying?
Old 11-02-2018, 03:36 PM   #5
DLGWRX02
DLGWRX02's Avatar
Make sure you have removed all traces of dirt before drying down, if you have some cotton swabs or pads to try in some inconspicuous areas to test for dirt levels otherwise you risk rubbing all them fine particles into your paint work. If you want to do this ide recommend using something like ONR (optimum no rinse) as a drying aid or as a wash method after snow foaming or using filtered water to rinse then you could leave with out touching it to dry naturally.
Old 11-02-2018, 03:37 PM   #6
Chris.91
(Un)luckily the car is already swirled (which will be corrected in future) so I will probably dry it. If it hadn't though I'd probably leave it to dry itself (in this case). Thanks.
The Following 2 Users Say Thank You to Chris.91 For This Useful Post:
DLGWRX02 (11-02-2018), leeandfay (12-02-2018)
Old 11-02-2018, 03:40 PM   #7
DLGWRX02
DLGWRX02's Avatar
To try prevent as much swirling as possible in drying, use different towels for each panel or a few panels just so not to drag dirt from one panel to another, I know you say you have swirls now but it’s always good to practice damage limitation if that makes sense.
Old 11-02-2018, 03:42 PM   #8
Chris.91
Good tip! Yes, definitely. And it's good practice to get it into the routine.
The Following User Says Thank You to Chris.91 For This Useful Post:
Old 11-02-2018, 04:41 PM   #9
OvEr_KiLL
OvEr_KiLL's Avatar
always best to foam and then wash, i used to only foam and then dry the car with a drying aid ie. quick detailer and the drying towel always picked up a little bit of dirt...
i then started to foam the car and then 2 bucket wash and there was still some dirt in the rinse bucket after the foam had been rinsed off
Old 11-02-2018, 04:47 PM   #10
cleslie
cleslie's Avatar
The only option really after a snow foam only wash is to blow dry with something like the Bruhl 2800. Did just that last week.
