Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Bilt Hamber
Bilt Hamber Bilt-Hamber Laboratories has always used research, innovative chemistry and thorough testing as the way to produce better performing products. Every product released for sale has been extensively compared to and tested for superiority against market leading and specialist competitive formulations. From our clay bars to cavity waxes, etch primers to carnauba waxes and shampoos to rust removers, each Bilt-Hamber formulation has been made from conception to production with the same care.
Old 05-12-2017, 01:00 PM   #1
youngwangie
youngwangie's Avatar
Auto-Foam
Thought I would try a no contact wash. Quater fill foam lance bottle, top with warm water,Spray car ( had 3/4 of it left usually its all gone) so left it couple min Sprayed again. Put wash buckets away, sprayed again. Jet wash off . this is what I GOT. Over kill. With foam I know, but not been washed for 3 week's M/way & daily drive through roadworks. I'm very impressed. Thanks for a great product fellas
Sent from my LG-H850 using Tapatalk
youngwangie is offline   Reply With Quote
The Following User Says Thank You to youngwangie For This Useful Post:
DLGWRX02 (06-12-2017)
Old 05-12-2017, 01:28 PM   #2
LeeH
LeeH's Avatar
Auto-Foam
I would have thought that dilution was a little low.
400-500ml/l seems to be average to get the 4% dilution on the vehicle. (Washer dependent obviously)
The Following User Says Thank You to LeeH For This Useful Post:
Beemerjohn (06-12-2017)
Old 05-12-2017, 01:39 PM   #3
youngwangie
Just a first time try. So I'm impressed, but as I say I went round the car 4 times. That could be the reason. You don't get a thick. Snow foam.its thinner than say Auto finess. But very pleased
Old 05-12-2017, 02:01 PM   #4
Soapybubbles
Soapybubbles's Avatar
Get yourself a pressure sprayer.
Put 80ml autofoam and 2L of warm water in it. Spray onto car, leave for 10mins,if it dries mist some water onto the panels.
You will not be disappointed with its cleaning ability when used this way
The Following 2 Users Say Thank You to Soapybubbles For This Useful Post:
luke w (14-12-2017), Sicskate (07-01-2018)
Old 05-12-2017, 08:32 PM   #5
James_R
James_R's Avatar
AutoFoam is great in a foam lance bottle hooked up to the pressure washer.
1.5" - 2" of AutoWash in a 500ml lance will give a good mix.
Results are superb, better than anything I've ever used, but at strong dilutions it can strip you wax/sealant to a certain extent.
Great on the underside of the car in winter though
Old 06-12-2017, 07:05 AM   #6
MaDMaXX
MaDMaXX's Avatar
Please don't give generic measurements for people using autofoam - the amount needed varies massively depending on the pressure washer used as well as the foam lance on top of the lance's setting.
It's best to use the DW autofoam review thread for the quick and easy method to set your own amount for your own equipment.
MaDMaXX is offline   Reply With Quote
The Following 4 Users Say Thank You to MaDMaXX For This Useful Post:
Brian1612 (07-12-2017), luke w (14-12-2017), macca666 (06-12-2017), steelghost (06-12-2017)
Old 06-12-2017, 08:31 PM   #7
James_R
James_R's Avatar
In fairness, two of us here have given the OP some measurements for using different methods of application without having to search somewhere else sifting through piles of posts that really aren't relevant to him.
These suggestions are in HIS thread.
1/4 fill that he used first time and having loads left would mean its too strong, but running too much water through, hence use less AutoFoam and a stronger dilution with the dial on the lance.
Old 06-12-2017, 08:35 PM   #8
MaDMaXX
MaDMaXX's Avatar
Ugh, alright, you called me out, here is the thread, it's very recent and was actually only below this one.
http://www.detailingworld.co.uk/foru...d.php?t=400542
The Following User Says Thank You to MaDMaXX For This Useful Post:
James_R (07-12-2017)
Old 06-12-2017, 08:39 PM   #9
macca666
macca666's Avatar
Have to disagree with your thought process there. Very few people on here would use 1l for a car I generally tend to get 3 to 4 cars out my foam lance meaning each use I'm only using 1/4 or 1/3 a bottle per wash. That doesn't mean my mixture is wrong and if you read Brian's recent review on here following dilution rates to the letter he only used 1/5 of his bottle.....
I think madmaxx is making the point that if manufacturers offer instructions then why not follow them rather than guess?
There's posts on here which aren't difficult to find so I don't see why the OP would have to sift through piles of posts which arent relevant
EDIT: I obviously type too slow madmaxx posted above whilst I was replying
Old 06-12-2017, 08:43 PM   #10
DLGWRX02
DLGWRX02's Avatar
Before jumping in, perhaps it’s best to read his post properly.
No mention of pw’s or lance through puts. And 80ml to 2 litres in a pump sprayer is bang on
