Old 06-12-2017, 10:34 AM   #1
Sam534
Sam534's Avatar
SRP by machine
Got some kicking around, never glazed with a machine before, though I'd give it a pop. Das6 pro, reckon I'll use my CG hex logic black pad.
Any advice? Machine speeds, arm speed, number of passes? Figure I'd get a ball park before going gungho.
Sent from my STF-L09 using Tapatalk
Sam534 is offline   Reply With Quote
Old 06-12-2017, 10:39 AM   #2
A&J
A&J's Avatar
2-3 passes, speed 2-3 (high enough to spin the pad), medium fast arm movement (you are not correcting so you dont need to go slow).
I dont think you can really mess this up whichever way you do it
Old 06-12-2017, 10:45 AM   #3
Sam534
Sam534's Avatar
Great, didn't think I would be able to mess it up. Glad this will be a quite quick and easy solution for my minor swirls on the daily driver. Shouldn't take long to do the car.
Old 06-12-2017, 11:13 AM   #4
Franzpan
Franzpan's Avatar
Yeah you can't go far wrong with SRP my machine. I use a white pad which I think adds a very very fine cut.
Franzpan is offline   Reply With Quote
Old 06-12-2017, 11:14 AM   #5
Sam534
Sam534's Avatar
What car? I'll use my black pad, should provide a very little cut on my Japanese paint
Old 06-12-2017, 12:14 PM   #6
Rayaan
Rayaan's Avatar
I use a white cc pad on both Lexus so you should be fine with a black pad
Old 06-12-2017, 12:15 PM   #7
Sam534
Sam534's Avatar
Perfect thanking you!!
Old 06-12-2017, 04:03 PM   #8
Yellow Dave
Yellow Dave's Avatar
SRP can work very well on a da. Just be careful with amounts used as I found the clogged the pad if i wasn't careful.
Old 06-12-2017, 05:13 PM   #9
Sam534
Sam534's Avatar
Right! I was just thinking 3 pea size dots for 1/4 of a panel to be rough
Old 07-12-2017, 08:59 AM   #10
virgiltracey
virgiltracey's Avatar
AG recommend a damp pad as well, I always keep a water bottle spritzer nearby when using SRP by machine
