Old 27-05-2017, 05:31 PM   #1
joe_con19
joe_con19's Avatar
Polishing behind door handles
Looking for a bit of advice or tips what people use for polishing behind the door handles which are badly scratched with people wearing rings etc
Sent from my Pixel using Tapatalk
joe_con19 is offline   Reply With Quote
Old 27-05-2017, 06:00 PM   #2
neilmcl
Would a polishing cone work?
Alternatively you could remove the handle. Personally I'd just try and hand polish it with a decent compound and small pad.
Old 27-05-2017, 06:11 PM   #3
bigalc
bigalc's Avatar
I just use a wo-wo sponge pad and some polish by hand.
Old 27-05-2017, 06:27 PM   #4
bradleymarky
bradleymarky's Avatar
Ultimate compound and a German app pad.
bradleymarky is offline   Reply With Quote
Old 27-05-2017, 09:15 PM   #5
neilmcl
The Following 2 Users Say Thank You to neilmcl For This Useful Post:
dellwood33 (28-05-2017), Tuska (11-07-2018)
Old 28-05-2017, 12:01 AM   #6
woodym3
G Tech P1 and a German applicator always works for me.
HTH
woodym3 is offline   Reply With Quote
Old 28-05-2017, 03:12 AM   #7
Yaro V
Yaro V's Avatar
I've had good luck using one or two fingers wrapped in a short-pile (or no pile) microfiber cloth with various polishes. Work the polish at different angles with straight lines then try to get some circles in too. I think the pressure that can be applied directly through the microfiber makes the polish work fairly fast.
Yaro V is offline   Reply With Quote
The Following User Says Thank You to Yaro V For This Useful Post:
Bean592 (28-05-2017)
Old 28-05-2017, 04:32 AM   #8
twk333
I'm an absolute newbie, and I've only tried this on 1 door handle so far (worried that I'd screw it up). I may stick on door handle film instead/afterwards.
I tried what Yaro V does, only I cut a small circle (2 cm?) of cardboard and used double-sided tape to keep the section of towel in place until I moved it to a clean part. I used more double-sided foam tape to keep it on my fingertip. It seems to keep it more uniform & into the "corners".
Obviously, all this is likely not necessary if you are skilled, i.e. not like me.
Sorry if that's confusing. It seems to have worked well, but, again, I am far from a professional.
Main reason I'm posting is that I'd appreciate someone telling me if this is a bad idea before I do the other 3. Thanks!
twk333 is offline   Reply With Quote
Old 28-05-2017, 10:45 AM   #9
nick_mcuk
nick_mcuk's Avatar
Send a message via MSN to nick_mcuk
Am I the only one that finds this guy in the vids insanely annoying?
nick_mcuk is offline   Reply With Quote
The Following 3 Users Say Thank You to nick_mcuk For This Useful Post:
Clarkey-88 (28-05-2017), huxley309 (12-02-2018), Tuska (11-07-2018)
Old 28-05-2017, 11:05 AM   #10
neilmcl
He is a bit. Personally I wouldn't have spent good money on a decent polishing pad just to cut it up like that, I'd have just got a microfibre spot pad in the first place and used that.
