Tools -Machine polishers, Pressure Washers, Detailing Equipment & Microfiber Sponsored by Detailed Clean : www.DetailedClean.co.uk Ė | Bilt Hamber | Dodo Juice | Nanolex | Sonus | Wolfs Chemicals + More | Loyalty Scheme Discounts |
Old 08-07-2018, 10:54 AM   #1
Shorthand
Iím confused
Hi guys,
Me again asking for help.
Iíve used microfibres pad with car pro rapid compound then yellow Rupes pad with there yellow fine polish, itís still leaving some kind of haze/hologram - Iíve gone over it again the the yellow and still there.
Please see the video - https://streamable.com/ip3a1 there no swirls just what ever that is. Was thinking to put grechniq panel wipe to see if that works
Any ideas?
Shorthand is offline   Reply With Quote
Old 08-07-2018, 01:43 PM   #2
mikster
mikster's Avatar
What car? Da or rotary? Did proper paint cleaning woth clay etc? Maybe u didnt get rid of the haze with the fine polish?
Not the best video. Hard to see
Old 08-07-2018, 06:04 PM   #3
Frog
Yellow isnít Rupes finest finishing polish, white is. May be you could try that ?
Old 08-07-2018, 07:39 PM   #4
Shorthand
I thought you us yellow pad and there yellow polish after machine for ďrefining/glossĒ?
DA all all the way, full paint clean - VW caddy 2014
Sorry itís hard to catch in a video I will try again later,
Old 08-07-2018, 08:39 PM   #5
mikster
mikster's Avatar
Strange, never had issues with rupes yellow pads as last stage.
Did u clean the pads after a couple of panels?
Old 08-07-2018, 08:57 PM   #6
cadmunkey
cadmunkey's Avatar
I'd say the same until recently, for the first time ever I didnt get 100% results on my car on two panels with the yellow. I cant see the OPs video very clearly but it might be the same result as mine. When the weather cools I am going to hit them again with the white pads and KC antihologram polish.
cadmunkey is offline   Reply With Quote
Old 08-07-2018, 09:34 PM   #7
mikster
mikster's Avatar
To be said...I never use rupes polishes or compounds with the yellow pads.
Only use scholl, sonax and Koch Chemie...
Old 09-07-2018, 10:18 AM   #8
Shorthand
I would like to say yes, but I'm not 100% sure.. I will try again later on with a clean pad
sorry the video is really bad and hard to get what I'm seeing on the video, it's like a haze but not a hologram as a no rotary was used.
I've only got the compound the rupes machines pad came with tbh
thanks all, hopefully I can try to remove what ever it is
Edit - is it worth going over it with a green pad/green polish it comes with?
Old 09-07-2018, 12:38 PM   #9
mdebeum
mdebeum's Avatar
I've had it a couple of times with rupes yellow on yellow pads and it turned out it was too hot and I found I had used too much polish which then dried up in the heat before breaking down fully.
Using less polish on a cool surface and breaking it down fully took care of the haze.
mdebeum is offline   Reply With Quote
Old 09-07-2018, 02:30 PM   #10
cadmunkey
cadmunkey's Avatar
This sounds exactly like the issue I have on my two panels. Not quite a hologram but definite haziness. If its cool tonight I will have another go with the Rupes white pad so will let you know if that solves it.
