Old 01-04-2018, 01:40 PM   #1
diesel_dog
diesel_dog's Avatar
UHD Shampoo and Karcher PW
Hi everyone, can you run the UHD shampoo through the detergent pick up on a Karcher PW if so any reccomendation for dilutions etc????
diesel_dog is offline   Reply With Quote
Old 01-04-2018, 01:53 PM   #2
wish wash
wish wash's Avatar
Are you trying to use your shampoo as a snow Foam?
Old 01-04-2018, 02:28 PM   #3
diesel_dog
diesel_dog's Avatar
No buddy just thinking after snow foam and rinse then spray shampoo mixture on then use mitt. Might be pointless but just seemed a good idea to try.
Old 01-04-2018, 02:34 PM   #4
I'd be tempted to have a go, but would probably use a cheaper shampoo to trial it out, as UHD is quite expensive and very good shampoo
Never bothered doing this with mine, neighbour has popped some BH auto foam in his and applied it to his car this way and worked well, so I suppose in theory you could...
diesel_dog (01-04-2018)
Old 01-04-2018, 02:36 PM   #5
OvEr_KiLL
OvEr_KiLL's Avatar
autoglym dont recommend using the new shampoo in a lance as its very very thick! so i reckon you might have a struggle with the pickup pipe
really good shampoo in a bucket
Old 01-04-2018, 02:54 PM   #6
diesel_dog
diesel_dog's Avatar
Makes sense I guess. From what I’ve seen of it int he bottle it is quite a concentrated mixture. I was thinking of diluting it in a bottle then running it through the detergent pipe. We will see.
Old 01-04-2018, 03:48 PM   #7
mokkaman
mokkaman's Avatar
Hi,I have tried using it in my foam lance,with mixed results.I used about 40ml/500ml of water.The mixture does not act like a snow foam,rather like a soapy lather.You can still use your mitt to spread the lather.Use the search button and you should find a related thread using UHD shampoo.Hope this helps Andy.
mokkaman is offline   Reply With Quote
The Following User Says Thank You to mokkaman For This Useful Post:
diesel_dog (03-04-2018)
Old 01-04-2018, 03:53 PM   #8
davep
Hi - I use the method all the time to dispense shampoo through my pressure washer ( I’m currently using a Kranzle but have previously had Karcher)
I use with all my favourite shampoos - BH, Dodo Juice and Anglewax.
Most pressure washers dose the detergent at around 4% through the low pressure detergent pick-up hose. So, you have to work out the dilution of your chosen shampoo so that it doses at the required strength. I notice that autoglym recommend using UHD at 4 capfuls per 10 litres. If the cap is say, 10ml this equates to 0.4%. So to get this through your pressure washer you will need to make up a 10% solution of UHD ( 0.4 x 100/4). I usually keep the solution in a spare 5 Ltr container and just stick the detergent pipe into this - works a treat!!
davep is offline   Reply With Quote
The Following User Says Thank You to davep For This Useful Post:
Old 03-04-2018, 11:10 AM   #9
Autoglym
Autoglym HQ
Autoglym's Avatar
Go for Polar Blast instead!
Old 03-04-2018, 12:03 PM   #10
Neat in the reservoir container or diluted down ?
autoglym, karcher, shampoo, uhd, uhd shampoo
