Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Race Glaze
Old 24-07-2018, 07:44 PM   #1
Deje
Di-vessle setup problem?
I want to connect my Vessel so that I can use my PW and my garden hose reel both with di-water and tap water, to make it work and without having to change connections, (a fixed installation), my solution is a 4. way connect coupling.
The potential problem with my setup is ,that when I just want to feed my PW or garden hose reel with tap water, it also wants to enter tap water into the vessle from the outlet intake. is that a problem?
Deje is offline   Reply With Quote
Old 25-07-2018, 05:08 PM   #2
RaceGlazer
Approved Trader
RaceGlazer's Avatar
I think I understand - how about a 2 way at the tap ( to normal hose and DI vessel) and then a 2 way off the Vessel to PW and open hose ?
Mark Wibberley
DW Approved Trader since 2009
www.raceglaze.co.uk
www.morethanpolish.com
www.carcovershop.co.uk
RaceGlazer is offline   Reply With Quote
The Following User Says Thank You to RaceGlazer For This Useful Post:
Deje (25-07-2018)
Old 25-07-2018, 06:42 PM   #3
Deje
Unfortunately, that solution does not allow you to use PW with tap water , sorry,It becomes a bit difficult to describe how I mean, my bad English does not help either!
A check valve on The Vessel is a solution, but then I have to crawl on the floor under a shelf to reach it. Unfortunately, I do not have any other surface to place the Vessle.
Is there a problem that it enters water through the outlet in to The Vessle?
Old 26-07-2018, 11:56 AM   #4
RaceGlazer
Approved Trader
RaceGlazer's Avatar
Any water that enters the vessel has to go through the resin bed. Hope that is clear and gives you the solution ?
Mark Wibberley
www.raceglaze.co.uk
Deje (26-07-2018)
Old 26-07-2018, 03:27 PM   #5
Deje
Thanks for the answer, my idea seems to be difficult to implement practically, so I have to abandon it.
So it will be the easiest possible instead, a 2-way on the water tap, and a hose to the garden hose reel and one hose to the PW.
