Old 10-04-2016, 11:01 AM   #281
ed87
Well done on the resto, great attention to detail and lovely to see the car in this condition
ed87 is offline   Reply With Quote
The Following User Says Thank You to ed87 For This Useful Post:
Willsy309 (10-04-2016)
Old 19-04-2016, 08:12 AM   #282
Willsy309
Willsy309's Avatar
Minor update
Removed the rear suspension entirely. At the very least I hoped to check it all over, clean everything up and regrease where necessary. With a bit of luck it would be MOT passable so that I could get some use out of the car over the summer.
Please excuse the mess
Got everything stripped down nicely but unfortunately I'm going to have to do the full rear beam refurbishment and rebuild now
Much wear here, outer bearing has dug itself in quite well
Other side not so bad but if one needs doing then both pins will be changed.
Various work around the house is limiting my funds for this at the moment so as things stand it'll be unlikely that I'll get to use it on the road this year. Shall just take my time with it.
So, I'll get all of the rear suspension bits and rear brake line brackets stripped and electroplated first.. Then bits which were coloured originally will be powder coated in their original colour/finish/closest match possible. I'm aiming for it to be done to as close to factory original as possible.
Surface rust removal still very much ongoing on the boot floor too. Will post pics when I make some more meaningful progress though.
Willsy309 is offline   Reply With Quote
The Following 4 Users Say Thank You to Willsy309 For This Useful Post:
Ben_W (19-04-2016), carrera2s (19-04-2016), SBM (19-04-2016), Tuddie (19-04-2016)
Old 16-06-2016, 09:59 AM   #283
SBM
SBM's Avatar
How is this coming along Willy? Any more updates?
SBM is offline   Reply With Quote
Old 16-06-2016, 12:00 PM   #284
ibiza55
Just read this from start to finish properly this time, took me all morning. In a way you were very lucky on the rust situation considering it didn't originally come far from the salty coast, never the less, your dedication to this motor is first class, if the drivers door could be repaired as I couldn't see any rust I would go down that route, coz at least you know what you have, and things can be pulled out now, what years ago would just have been scrapped, keep the updates coming mate.
Old 22-06-2016, 02:33 PM   #285
Willsy309
Willsy309's Avatar
Afternoon all, apologies for the lack of updates lately.
I have been getting the odd bit done which has been mostly dismantling the rest of the rear suspension assembly and gathering some new bits.
I still need to drop various bits off to be electroplated which are too big to do in my home kit. They'll then go for powdercoating over the top in the original (close as possible) colours.
The rest of my time, which has been minimal to be fair, has been spent doing the rust removal on the rear end.
After having a good poke and a prod (see before pics on the previous page) I was finding that the surface rust was starting to creep under bits of the factory stone chip finish which from simply looking at the stone chip looked in perfectly good order.
So as with the rest of the work so far there's just no point in doing things by halves or settling for a temporary job of rust treatment.
I've decided to completely strip it back to back metal. I figured out that Nitromors does a nice enough job of softening and loosening the factory stone chip and compromised original galvanised costing underneath it. Then it's been the lengthy job of applying Bilt Hamber Deox Gel to get rid of the surface rust. I'm not a believer in the rust converter type products so it's got to be rust free metal.
Here's how things are looking anyway
I've got further with the passenger side here
Almost caught up
It's going to take me a good while longer but it's got to be worth it in the long run
The Following User Says Thank You to Willsy309 For This Useful Post:
Tuddie (22-06-2016)
Old 22-06-2016, 04:14 PM   #286
Tuddie
Tuddie's Avatar
Send a message via MSN to Tuddie
Lookin good mate, as you say plenty of work in that, good luck!
Tuddie is offline   Reply With Quote
Old 22-06-2016, 07:15 PM   #287
ActionTracked
ActionTracked's Avatar
I love this thread willsy!
The work with the Bilt hamber is great viewing, I can't wait to try some out. The will be such a great example when complete
ActionTracked is offline   Reply With Quote
Old 23-06-2016, 06:15 PM   #288
Rsam
Rsam's Avatar
Send a message via MSN to Rsam
Brilliant thread, just read it from start to finish!
Rsam is offline   Reply With Quote
Old 26-06-2016, 12:55 PM   #289
Willsy309
Willsy309's Avatar
Just a couple to show how long this is taking
This is another 2 hours work since the last set of pics. Doesn't seem like much difference
sshooie (26-06-2016)
Old 26-06-2016, 04:43 PM   #290
tomsuematthews
tomsuematthews's Avatar
I hope the juice is worth the squeeze but I salute you sir, what an unbelievable job!
tomsuematthews is offline   Reply With Quote
