Old 09-10-2017, 03:28 PM   #1
stephentw
Should I get a DA? New car polish/wax
Hi, been reading for a while but not really posted much. I'm getting a new Honda Civic (metallic blue) and wanting to get it well protected from the off so I'm getting some new things (clay glove, possibly a DA, claying will be a first for me and this seems like a good starting point from what I've read).
So firstly do I need to polish a new car (I think the consensus is generally yes) and would I be best doing it with a DA if I've never used one or have some minimal practice on my old car and girlfriends car before I get the new one?
I've been watching videos on YouTube (some by a member here I think) and it seems like something I could pick up fairly easy I think but I don't want to be over confident.
Also if I get one what polish is appropriate for a Civic? I've read paint is soft and people recommend hexalogic pads in white for polishing and black for finishing on this type of paint. Feel a bit undecided on the polish though. I've read about scholl? I think and chemical guys. But don't know much about grades or what is appropriate for my paint. I have some dodo juice lime prime but that's more for prep I think.
Can I use a DA for sealant (I have BH auto balm) and lime prime too? There's so much information I feel confused. Help!
stephentw is offline   Reply With Quote
Old 09-10-2017, 05:03 PM   #2
Harry_VW
DA's are generally very safe to use. I would suggest buying 3 grades of polish and three grades of pads. Then use different combinations to find out what is required for your paint. Start at the least aggressive and work your way down. Yes they can be used to apply LSP
Harry_VW is offline   Reply With Quote
Old 10-10-2017, 11:48 AM   #3
stephentw
Ok thanks for that. Any recommendations on the type of polish? How will I know what is good for my paint? I've never used these types of polish as by hand I only ever used auto glym and Meguiars.
Old 10-10-2017, 12:19 PM   #4
Harry_VW
Some options would be: Scholl, s3, s20, s40. Menzerna FG400, SF2400, SF4000/3800.
There are many options out there to discover
Old 10-10-2017, 01:16 PM   #5
For soft paint I find that water based polishes like Sonax perfect finish with either a white hex quantum polishing pad or green if you have deeper swirls are a very good combination.
Before you decide which to go for I would suggest you practice on a scrap panel before you go near your paint as soft paint isn't very forgiving.
Old 10-10-2017, 10:08 PM   #6
Mark@PD
Mark@PD's Avatar
Hi Hope you enjoy your new car. Don't forget to use a fallout remover and tardis, just because it's new doesn't mean it won't need them.
Old 10-10-2017, 10:40 PM   #7
Forsh
Forsh's Avatar
When you check out some of the new car details in "The Studio" it's surprising how many defects show up on a new car.
Sadly it seams many are caused by the dealer rather than from the factory (but not exclusively) so first step would be to ask the dealer not to "prep" it and have it delivered with all factory protection in place.
Then take it from there as to how much correction it requires
Safe wash is an obvious must
Old 11-10-2017, 10:53 PM   #8
stephentw
Thanks everyone. I think the s40 scholl is something I've read being good for Honda paint before actually. I'll look into sonax too. Do these leave white residue in every little crack? I disliked that about polishing by hand.
I have ironx for wheels, is that a fallout remover? I know it can be used on paint too. No tardis yet but it's on the list.
I did think about getting the garage to not prep it but I'm not sure when I'm going to get chance to do all this because I'm tied by the weather, no big garage to work in unfortunately so I'm going to collect the car as normal and go from there. My plan is:
Snow foam
Wash/dry
Iron x
Tardis (or is this better before ironx)
Rinse
Clay mitt
Polish
Clean polish off (ipa I think?)
Sealant
Does that look good?
Couple of questions, I have bilt hamber auto balm and optiseal sealants. I previously used BH on paint and Optiseal on wheels. Is one better than the other, should I just use one for the whole lot?
Old 04-01-2018, 10:52 AM   #9
olliewills
Honda paint is indeed very soft (oh the rock chips!). I've used Megs #105 and #205 on my two 8G civics with good success so you could also go that route. Definitely worth seeing if you can get the dealer to deliver the car with its factory protection still in place.
Sent from my One using Tapatalk
Old 04-01-2018, 11:12 AM   #10
MGJ92
MGJ92's Avatar
I'd recommend the Rupes DAs, polish and pads, we've had good results using their colour system.
For my mates S2000 we found a two stage polish with a green pad followed by a white finisher gave a great result, it is an older car though so had more imperfections than yours will (hopefully!). You'll probably only need a single stage with a light combination. Post up some pictures when you're done so we can see!
MGJ92 is offline   Reply With Quote
