Old 09-01-2018, 03:52 PM   #1
euge07
euge07's Avatar
new wax applicators
https://www.ebay.co.uk/itm/FINGER-WA...sAAOSwR8haT1F4
on the lookout for some new wax applicators, fed up with with current ones, 5inch round foam pads,
anyone using the above?
Old 09-01-2018, 04:02 PM   #2
KRM
Have you ever tried the foam applicators from Waxaddict?
I like these pads too
https://www.elitecarcare.co.uk/produ...pplicator-pad/
KRM is offline   Reply With Quote
The Following User Says Thank You to KRM For This Useful Post:
euge07 (09-01-2018)
Old 09-01-2018, 04:05 PM   #3
euge07
euge07's Avatar
no, I will look them up now,
Im looking a smaller style pad, I'm interested in the handi puck from Autofinesse but the replacements pads are expensive
The Following User Says Thank You to euge07 For This Useful Post:
KRM (09-01-2018)
Old 09-01-2018, 04:53 PM   #4
neilmcl
This is what I use as my hands tend to cramp when using normal pads. As far as expense is concerned any 75-100mm spot pad will fit, although I wouldn't necessarily call £4.95 expensive for a pad.
Old 09-01-2018, 05:17 PM   #5
I use the Serious Performance handi puck plus these spot pads, £2.50 each.
I'm sure someone posted about a discount set of pads from AliExpress for use in this way as well.
euge07 (10-01-2018)
Old 09-01-2018, 05:28 PM   #6
Hereisphilly
Hereisphilly's Avatar
There's quite a few cheap ones on eBay, 4 off for £2 delivered
Do the job perfect for wax application with a puck
Sent from my Pixel 2 XL using Tapatalk
Old 09-01-2018, 06:48 PM   #7
LewisChadwick7
LewisChadwick7's Avatar
As mentioned above I use an auto perfection puck with these (yellow and black perfect for waxing) https://m.ebay.co.uk/itm/3pcs-3-80mm...wAAOSw5dNWjuVW
Old 09-01-2018, 07:13 PM   #8
Hereisphilly
I found one that even better value if someone fancies a punt?
Bit dubious listing but at £7 it's not going to break the bank
https://rover.ebay.com/rover/0/0/0?m...2F162493222452
Old 10-01-2018, 09:43 AM   #9
euge07
euge07's Avatar
It is expensive per pad if you are doing quite a number of cars and not keen on rewashing them every time etc, I prefer to use clean pads
Cheers SG, will check them out
thanks chaps
Old 10-01-2018, 10:14 AM   #10
Peter77
Peter77's Avatar
https://www.samsdetailing.co.uk/prod...y/accessories/
Sams detailing do some nice looking applicators for wax, tyre dressings etc
