Old 11-01-2018, 07:59 PM   #21
percymon
If your PW will fit side ways under the tumble drier then a high pressure link hose (perhaps needing a 90’ elbow at the PW outlet) to a externally mounted HP hose reel would be a relatively tidy option. At least the PW could be static then. If you are using over 15m of hose you will probably need the 2 wire larger diameter hose to reduce pressure drop to the gun. A gun with quick release connection would allow the HP hose to be reeled in after use easily
The Following 2 Users Say Thank You to percymon For This Useful Post:
Hereisphilly (11-01-2018), steelghost (11-01-2018)
Old 12-01-2018, 10:54 AM   #22
This is an interesting resource to size the pressure loss you might experience.
It's all in US units, but 2 US gallons per minute is about 7 litres a minute; 1/4" hose is roughly 6mm ID (ie DN06), and 5/16" hose is approx 8mm ID (DN08). Pressure loss reduces at lower flow rates.
20 psi is 1.37 bar, so for a 30m (~=100ft hose) you're talking a 12 bar loss in pressure for DN06 hose, vs a 4 bar loss for DN08 hose (at 7.6lpm)
Old 12-01-2018, 02:32 PM   #23
Soapybubbles
Soapybubbles's Avatar
Glad you got round to setting this thread up SG!
Here is my lance new set up for my Karcher K5
Purchased from Damian at Qwashers
My next purchase will be a new hose as I'm fed up with the standard green hose and reel toppling over the PW and coiling up constantly.
SG will a new hose from Qwashers not coil up so much like the standard karcher item?
The Following User Says Thank You to Soapybubbles For This Useful Post:
steelghost (12-01-2018)
Old 12-01-2018, 05:06 PM   #24
My experience of rubber and steel wire hoses (ie "proper" hoses ) is that they basically want to be straight, the only exception is if you apply a twist to them - then they will coil up because of the steel wire in them. This is particularly true for dual-wire hoses - less so for single wire types.
You mention a reel - I've seen that some of the Nilfisk machines can be problematic to replace or upgrade hoses, it's worth checking before you order anything how it would replace the existing hose (you might already have checked this but thought worth mentioning in case).
Old 12-01-2018, 05:08 PM   #25
Deje
How is the Nozzle Protector mounted? Saw Matt moreman mount it on his mosmatic lance, looked a bit awkward.
Old 12-01-2018, 05:27 PM   #26
Dazednconfused
Hi Soapybubbles,
Are the QR's from the gun standard 11.6mm quick releases?
If yes, where did you get QR attachment for the snow foam lance?
Phil
Dazednconfused is offline   Reply With Quote
Old 12-01-2018, 07:42 PM   #27
Soapybubbles
My intention was to no longer use the hose reel mechanism on my karcher when I get the new hose
I planned on hanging it on a hook off my garage wall to store when not in use.
My original hose has a quick connect type into the motor, I was hoping to order a non karcher type hose so that when my pw gives up I can re use the new hose. Not sure how I would plumb that in? but will speak to Damian at nearer the time
Old 12-01-2018, 07:45 PM   #28
Soapybubbles
It just slides on I think,I can move it back if need be, it was already attached when I got it
Deje (13-01-2018)
Old 12-01-2018, 07:48 PM   #29
Soapybubbles
Originally Posted by Dazednconfused View Post
Hi Soapybubbles,
Phil
That's correct they are indeed 11.6mm QR
I got the snow foam attachment from Damian at Qwashers
1xmini male x 1/4 female QR £1.08
Hope that helps
Old 12-01-2018, 08:56 PM   #30
percymon
Anyone looking for a new gun ( and fittings etc) should have a look at
www.malcleanse.co.uk
Ordered this gun today, together with a 3/8" male to 19.5mm QR male (plus some dowty washers and other odds n sods)..
Colour might not be to most peoples tastes but with built in stainless steel swivel, low force trigger and a spec of 310Bar max and 45l/min max , and 150'C capability it can cope with pretty much most machines output. Its from Suttner's 'professional' (eg petrol station car jet wash use) so is going to be robust and reliable - better spec than the ST-2600 in their more usual 'detailer' range.
steelghost (13-01-2018)
diy, pressure, upgrade, washer
