A recent change to a white car has made me decide sealant is the way to go. I remember someone posting on here that sealants generally suited white or grey paint better so this made me want to experiment with sealants.
To keep things simple I’ve narrowed the choice down to three sealants I can source fairly locally. I have listed these in no particular order and with some reasons I want to try them.
• Poorboys EXP – have wanted to try this out for a while as I have the full PB polish range and find they work really well with the waxes SSR polishes and Natty’s wax and think they are amazing so am thinking the pure sealant should produce some great results. Only thing that bothers me somewhat is the durability – some here have said it’s as little as 3 months, which in my mind is pretty rubbish for a sealant
• Zaino Z2 – reports of people using this seems to be fairly consistent in that the durability seems to be very good and the looks offered are good. Already tried Clear Seal on the glass of a previous car and wasn’t overly impressed, found it attracted more dirt than it repelled, although I probably applied far too much.
• Auto Finesse Power Seal – this seems to be the most durable of the whole lot (upwards of 6 months apparently), but the real selling point for me is this one can be applied by machine, which as far as I am aware none of the rest can.
Paint prep will be the same regardless of which of the above is used – full degrease wash, de-tar/iron, clay then DA polish with PB SSR 2 or 1 depending on paint condition.
So, from the choices above, what would you pick if you were sealing a solid white car? Money is no issue here, but please can you limit your responses to one of the above choices.
Thanks,
R.
Thanks,
R.
