Old 13-02-2018, 07:09 AM   #1
ShaunTV4
ShaunTV4's Avatar
Hologram
Hi all,
So, over the weekend, I tried to DA my car. It’s a 54 Toyota Yaris in Black, I used a Meguiars DA on speed 4, a Meguiars yellow polishing pad and Meguiars Ultimate Compound.
All seemed to be going well until I wiped the remaining compound off, I was left with hologram type marks I was pressing down with a medium force and had a lot of product left on the surface after polishing for over a minute, too much product used?
Any tips on how/ pads/polish to fix this error? Recommendations of a better combo will be greatly appreciated.
Thanks,
Shaun.
ShaunTV4 is offline   Reply With Quote
Old 13-02-2018, 09:14 AM   #2
Sh1ner
You started off a little strong.
I would try something much lighter at first like ultimate polish/M205 either on your yellow Megs pad or a CG hex black or white pad.
Ultimate compound might be necessary but work up to it. It is very dusty and stains trim easily though. I find Megs M101 and suitable pad much better but there are many different combos that will give good results.
It also sounds like your technique could do with some refinement.
A scrap or practice panel might be useful.
The Following User Says Thank You to Sh1ner For This Useful Post:
ShaunTV4 (22-02-2018)
Old 13-02-2018, 09:52 AM   #3
bradleymarky
bradleymarky's Avatar
Pretty sure M205 is designed for hologram removal but also one of the best polishes around.
bradleymarky is offline   Reply With Quote
The Following User Says Thank You to bradleymarky For This Useful Post:
Old 13-02-2018, 09:52 AM   #4
cossiecol
Moderator & Reviewer
cossiecol's Avatar
There could be any number of reasons for the holograms, however the most likely reason in an incorrect technique.
Have a look in the guide http://www.detailingworld.co.uk/foru...d.php?t=281047
Follow the above guide and you should see improvements. After you've sorted your technique you can then look at the pads/compound etc
Old 13-02-2018, 12:30 PM   #5
ShaunTV4
ShaunTV4's Avatar
Many thanks all, I’ll have a look at the videos and maybe try and get a finer polish
Old 13-02-2018, 12:42 PM   #6
Alan W
Alan W's Avatar
Definitely sounds like technique as you should be polishing for a lot longer and until the polish has broken down.
This guide is one of the best although the photos are no longer showing:
Machine Polishing by Dual Action Polisher - Full Guide
Alan W
Old 13-02-2018, 01:26 PM   #7
ShaunTV4
ShaunTV4's Avatar
Alan W
Should the polish go clear before stopping? When I thought I’d done enough, it was still while on the surface.
Old 17-02-2018, 10:32 AM   #8
Mark@PD
Mark@PD's Avatar
There are so many variables speed technique polish pad combination did you work the polish long enough was there any contamination on the paint grit In the air was the pad overworked did it have excess product on it should it have been changed.
The Following User Says Thank You to Mark@PD For This Useful Post:
