Defined Details - Audi A4 (Cquartz Finest + Polish Angel approved)
The Home of Vehicle Perfection.
Email: info.defineddetails@gmail.com | Tel: 07817 224 869.
www.defined-details.co.uk
I was contacted by the owner of this lovely Audi A4 S Line. He had recently purchased this from down south and was to be used by his wife and a general daily driver. Whist he was offshore. During the conversations. It became apparent he was looking for a durable form of protection and he mentioned Ceramic coatings. We discuss the plus point and well as the slight negatives that can occur and due to the fact that the vehicle and the family home is by the East Coast of Scotland. Salt and spray would have to be considered. Generally salt does not effect the coating as in durability. It does have a high mineral content and can be prone to cause water spotting with certain coatings.
After this conversation. Both parties agreed on CquartzUK and topped off with Polish Angel Cosmic. This would cover all the key areas discussed and has the benefits the client wished for.
The Audi was booked in for a Dual stage machine correction. Increasing the gloss and clarity in the finish, Whist offering a reduction on deeper marks, as the car could not be viewed at this time.
Car on arrival. After travelling 60 or so miles in a rather wet and cold day in Scotland. Once viewed the service was clarified and work commenced with the standard wash process.
Wheels Tyres and arches where first to be addressed. APC used on under arch areas and Degreasers used on the tyres surface. Agitated with various brushes and rinsed off. The wheels where first cleaned with Smartwheels and then treated for tar with Tradis. Prior to a follow up treatment of Iron X to remove any metal fallout.
DSC_0002 by defined.details, on Flickr
DSC_0003 by defined.details, on Flickr
2 snow foam and rinsed of varying consistencies and rinsed off.
DSC_0009 by defined.details, on Flickr
Various brushes where used to clean the hard to reach areas and remove any build up of grit or grim.
DSC_0011 by defined.details, on Flickr
DSC_0010 by defined.details, on Flickr
At this point the weather turned foul. So no photos where taken of the safe 2 bucket wash and claying. The car was moved into the unit and dried safely with various air drive tools. Prior to full wipe down of the paint work with 7010.
Paint readings where once more taken coupled with a visual inspection of the defect present on each panel. Which lead to a few test sets being carried our. To gauge removal rates couple with defect removal. This was also used as an indication as to the hardness on the paint being worked on.
All areas that required further correction was first tackled with Sonax Perfect finish on a CG Orange pad. And the full car once correction was completed refined and prepped with Polish Angel 9H Primmer on a polish pad.
Before and after shots as I moved around the car. Still to be refined at this time.
Front wind and unfortunately slight road rash.
DSC_0203_Fotor_Collage by defined.details, on Flickr
Off side front door.
DSC_0209_Fotor_Collage by defined.details, on Flickr
DSC_0216 by defined.details, on Flickr
DSC_0217_Fotor_Collage by defined.details, on Flickr
Off side rear door.
DSC_0227 by defined.details, on Flickr
DSC_0233_Fotor_Collage by defined.details, on Flickr
Rear 3/4 panel, rear end & bumper
DSC_0258_Fotor_Collage by defined.details, on Flickr
DSC_0266_Fotor_Collage by defined.details, on Flickr
DSC_0270_Fotor_Collage by defined.details, on Flickr
DSC_0284_Fotor_Collage by defined.details, on Flickr
DSC_0274_Fotor_Collage by defined.details, on Flickr
DSC_0277_Fotor_Collage by defined.details, on Flickr
DSC_0280_Fotor_Collage by defined.details, on Flickr
Near side 3/4 panel
DSC_0287_Fotor_Collage by defined.details, on Flickr
Near side rear door
DSC_0300 by defined.details, on Flickr
DSC_0309_Fotor_Collage by defined.details, on Flickr
Near side front door.
DSC_0313_Fotor_Collage by defined.details, on Flickr
Near side front wing
DSC_0356_Fotor_Collage by defined.details, on Flickr
The full car was the refined and prepped for CquartzUK to be applied. After Cquartz was applied it was rather late in the day. To the application od Cosmic was left to the following day.
Few picture of the Audi late into the evening and under fluorescent lighting.
DSC_0459 by defined.details, on Flickr
DSC_0452 by defined.details, on Flickr
DSC_0451 by defined.details, on Flickr
The following day the car was treated to two coats of polish angel cosmic. Leaving a stunning candy gloss look to the Milano red paint. All wheels, tyres sealed and protected and all glass and plastic trims protected.
Thanks for taking the time to view and read this post and all comments welcome.
Regards Gordon.
DSC_0505 by defined.details, on Flickr
DSC_0681 by defined.details, on Flickr
DSC_0523 by defined.details, on Flickr
DSC_0543 by defined.details, on Flickr
DSC_0544 by defined.details, on Flickr
DSC_0566 by defined.details, on Flickr
DSC_0577 by defined.details, on Flickr
DSC_0597 by defined.details, on Flickr
DSC_0601 by defined.details, on Flickr
DSC_0623 by defined.details, on Flickr
DSC_0659 by defined.details, on Flickr
DSC_0660 by defined.details, on Flickr
DSC_0662 by defined.details, on Flickr
DSC_0538 by defined.details, on Flickr
DSC_0696 by defined.details, on Flickr
DSC_0673 by defined.details, on Flickr
DSC_0685 by defined.details, on Flickr
Off side rear door.
Near side 3/4 panel
Near side rear door
Regards Gordon.
