Defined Details - Ariel Atom Cleanse & Protection Plus (Stripped down)
20K views 25 replies 22 participants last post by  badly_dubbed
The Home of Vehicle Perfection.
Email: info.defineddetails@gmail.com | Tel: 07817 224 869.
www.defined-details.co.uk
Ariel Atom - Cleanse & Protection Plus (Stripped down)
The owner of the Ariel Atom has previously book his toy in for a cleanse and Protect detail, with a few bolt on services. This was to take place after a weekend away with a group of lads and their trip around the Highlands of Scotland. Little did he know the weather on this weekend would turn foul and got caught on numerous occasions with a wall of water travelling toward him off HGV coming in the opposite direction. As you can imagine this also contributed in getting grim git in every area of the exposed Atom.
Atom on arrival on yet another wet and dreary day in Glasgow.
defineddetails.P1550471 by defined.details, on Flickr
The atom was treated as all vehicle booked in for a detail. Wheels and tyres pre cleaned. Prior to the full car receiving 2 snow foams and rinsed. Although this has to be the first time I have snow foamed and interior. The car was the 2 buckets washed and the engine was degreased and worked over with various brushes. Once again prior to being rinsed and brought indoors to be clayed.
P1550476 by defined.details, on Flickr
Once all gel coated panels where clayed they were put to one side, as these would be machine polished and protected prior to reassembly.
defineddetail.P1550478 by defined.details, on Flickr
The wheels where removed and once again taken out side to be fully cleaned and remove all fallout present. These where later clay bared and wiped down with 7010 prior to being coated, with Max protect UNC-R.
defineddetail.P1550475 by defined.details, on Flickr
Steam cleaning was then carried out on the engine and all suspension components as well as the brake callipers. Once I was happy with the callipers. These where as before wiped down and sealed this time with Carpro Dlux.
defineddetails.P1550532 by defined.details, on Flickr
One area that would require some work was the exhaust. Discoloured due to the heat and water from the owners trip up North.
defineddetails.P1550474 by defined.details, on Flickr
Due to the arduous nature and sore fingers. Due to lack of access most of this would have to be hand polished with the britmax twins. The rear box was later removed so as to gain access to the rear of the silencer. I jumped between exhaust and the rear suspension components. Cleansing and sealing as I went with Plish Angel Esclate and Master sealant.
defineddetails.P1550534 by defined.details, on Flickr
P1550544 by defined.details, on Flickr
50/50 on the rear silencer. protection all other areas from metal polish splatter.
P1550563 by defined.details, on Flickr
Rear box removed to gain access and polish the rear sections.
P1550572 by defined.details, on Flickr
Prior to rebuilding and to give my sore fingers a rest. I moved on to cleansing the hard plastic grp section on the nose cone and dash, with polish angel esclate.
P1550522 by defined.details, on Flickr
P1550523 by defined.details, on Flickr
These areas would be protected with Polish Angel master sealant, at the same time as the frame was completed. I moved on to the GRP gel coated panels.
Before shots
defineddetails.P1550510 by defined.details, on Flickr
And after correction.
defineddetails.P1570556 by defined.details, on Flickr
The mud guard where also corrected. But I have misplace these pictures.
The exhaust was reassembled. Prior to completed the engine area and all suspension parts.
P1550576 by defined.details, on Flickr
P1550580 by defined.details, on Flickr
All gel coated, painted and running gear was cleansed and protected with Master sealant.
P1550601 by defined.details, on Flickr
P1550599 by defined.details, on Flickr
P1550591 by defined.details, on Flickr
P1550596 by defined.details, on Flickr
P1550597 by defined.details, on Flickr
P1550614 by defined.details, on Flickr
P1550617 by defined.details, on Flickr
P1570577 by defined.details, on Flickr
All rubber heating pipes. Drive shaft bellows and textured hard plastic areas where treated with Carpro Perl as 1 to 1.
P1570582 by defined.details, on Flickr
P1570585 by defined.details, on Flickr
Seats and internal **** pit areas also treated and protected with Perl. The harnesses when then reattached.
P1570593 by defined.details, on Flickr
Comfort seating pads as before treated with perl and the foot supported had it brushed finish restored, as it was previously scratched.
P1570588 by defined.details, on Flickr
P1570589 by defined.details, on Flickr
Wheels where finally sealed with a top up layer of master sealant. Prior to refitting and torqued up to the correct requirements.
P1550619 by defined.details, on Flickr
At this point nursing many sore and skint fingers. I will leave you with some after shots. Once again thank you for viewing and reading this post and I hope you have enjoyed it as much as I did completing the work.
Gordon.
P1570644 by defined.details, on Flickr
P1570645 by defined.details, on Flickr
P1570648 by defined.details, on Flickr
P1570650 by defined.details, on Flickr
P1570654 by defined.details, on Flickr
P1570655 by defined.details, on Flickr
P1570659 by defined.details, on Flickr
The little and large show.
P1570974 by defined.details, on Flickr
Some real dodgy guys around.
P1580103 by defined.details, on Flickr
Might have bitten off more that it can chew here
P1580105 by defined.details, on Flickr
P1580110 by defined.details, on Flickr
P1580114 by defined.details, on Flickr
Thank you once more and all comments welcome.
Regards Gordon.
See less See more
46
#5 ·
Yes I did. The owner was kind enough to take me out for a small spin on the 74 and had the pleasure of driving it back. The sound of the supercharger right behind you head is something else. But passing HGV and you not even up to the wheel nuts is a tad daunting. :lol:
excellent work as always mate!
Thanks M8. Do not see you on here often. Hope you are well. :thumb:
Was wondering when that was going to be posted nice work G
What can I say. Running a good few months behind :lol:. We will work on through it though. :thumb: Hope you are well also Sup's
