Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > CarPro-Cquartz
Old 09-04-2014, 08:05 PM   #11
sm81
http://www.detailingworld.co.uk/foru...d.php?t=335212
Old 09-04-2014, 08:22 PM   #12
Bristle Hound
DW's Biggest Thread Starter & Moderator
Bristle Hound's Avatar
Must be a typo, the quoted 1:1500 IMO
If you click thro' one of the hyper links on that thread to the Elite website they quote a 1:500 dilute ratio on the product details
http://www.elitecarcare.co.uk/carpro...mpoo-500ml.php
Sent from my iPad
Bristle Hound is offline   Reply With Quote
The Following User Says Thank You to Bristle Hound For This Useful Post:
Andy G (25-01-2015)
Old 10-04-2014, 11:08 AM   #13
CarPro.UK
Carpro UK
CarPro.UK's Avatar
Thanks for the Review Pugnut,
As for the dilution,
Shampoo as a cleaner will work at most dilutions, and it varies effectiveness based on the water hardness, I've found the shampoo works effectively to remove dirt and road grime up to around 1:800.
However, to work as designed, and remove oils and surfactants blocking the surface of Cquartz products 1:500 is the ideal solution for UK customers,
The 1:1500 I believe was a typo when one of the resellers listed it on their website which has been quoted and re-quoted leading to confusion.
As for the label suggesting 1:400, this isn't our department however it could be that the labels were designed for US market where the water hardness effects the shampoo more. You will find a lot of big name US brands, when you import the shampoo to the UK the dilution ratios are stronger than required for the UK.
Hope this helps.
Craig
CarPro UK
CarPro.UK is offline   Reply With Quote
The Following User Says Thank You to CarPro.UK For This Useful Post:
Blackmondie (27-07-2014)
Old 12-05-2014, 09:00 PM   #14
John_Adelaide
Just received and tried this new shampoo out (over cquartz finest), WOW!
- Cleaning abilities, most impressive!
- A little really goes a long way.
- Great suds & slickness, in fact the most suds experienced from any shampoo I've tried.
- Pleasant neutral smell, non overpowering whatsoever - no BS.
I really liked the ironx soap gel (still have and use - great for bug guts),
and the snow soap has been my daily 2BW product. It's great to see this
shampoo compliment the cquartz system, will definitely be using it between
polishing wipe downs also, very, very impressive cleaning abilities.
Can't and probably won't be able to comment on how this would result in washing over wax, as all our vehicles are cquartz coated.
Excellent work gentlemen.
John_Adelaide is offline   Reply With Quote
The Following 2 Users Say Thank You to John_Adelaide For This Useful Post:
CarPro.UK (28-07-2014), Cquartz (13-05-2014)
Old 27-07-2014, 03:04 PM   #15
sm81
Any samples for this? I have reseller near to me but doesn't want to buy more shampoos before knowing is it as good than BH Autowash
Old 19-10-2014, 04:37 PM   #16
sm81
How you would compare it against BH Autowash/BTBM/Lather?
Old 19-10-2014, 11:48 PM   #17
CarPro.UK
Carpro UK
CarPro.UK's Avatar
Hi Sm81, hopefully one of the other members can answer this for you, while I have used the mentioned shampoos I would not wish to make comment on someone elses products vs our own as it would be seen as biased.
Craig
Old 26-10-2014, 04:59 PM   #18
sm81
Nobody??
Old 26-10-2014, 09:34 PM   #19
xJay1337
xJay1337's Avatar
Carpro reset is my favourite shampoo.
xJay1337 is offline   Reply With Quote
The Following User Says Thank You to xJay1337 For This Useful Post:
CarPro.UK (26-10-2014)
Old 26-10-2014, 09:43 PM   #20
sm81
Ok. But why? I can tell why BH Autowash is mine but maybe not here.
