Old 27-09-2016, 06:39 AM   #1
Justanothersept
Question Preparing for paint correction. Help
I'm doing my first paint correction. Never really prepared for it only do normal bucket washes. This is what I'm guessing that will work. Only issue is that there's a lot of rinsing. Anything I can cut down on the 'prepare' list
Prepare:
Snow foam
Rinse
Tar remover w/ mf
Rinse
Iron remover
Rinse
Clay mitt w/ shampoo
Rinse
3 bucket
Rinse
Hose sheet
Dry w/ Meguiar's waffle
Diluted Qd w/ MF
Polish paint correction:
Meguiar's 105 with orange pad
Meguiar's 205 with white pad
Collinite 845 with black pad
Top up:
Gtechniq c2v3 w/ MF
Any help would be great.
Justanothersept is offline   Reply With Quote
Old 27-09-2016, 06:42 AM   #2
graham1970
graham1970's Avatar
After each polishing stage it would be best to use panel wipe,eraser or ipa to remove oils,especially before waxking.
What's with the 3 bucket wash mate...??
Sent from my D5803 using Tapatalk
graham1970 is offline   Reply With Quote
Old 27-09-2016, 06:48 AM   #3
scratcher
scratcher's Avatar
Go with...
Wheels,
Snow foam,
Rinse,
Wash,
Loosely dry, then tar, etc. As avmbove, a rinse between each decon stage too
scratcher is offline   Reply With Quote
Old 27-09-2016, 09:55 PM   #4
lowejackson
lowejackson's Avatar
As above, 3 buckets? Seems to be a lot of rinsing but are you sure that combination of pads and polish are correct for your paint
Old 27-09-2016, 11:18 PM   #5
Daytona675
You should be using the tar remover, iron remover and clay bar AFTER the wash stage, not before. You could save a rinse stage by doing the following
Snow Foam
Rinse
Bucket wash (2 or 3!?)
Rinse
Tar remover
Rinse
Dry (to give a better dwell for next step)
Iron remover
Rinse
Clay
Bucket or snow foam
Rinse
Completely dry
Then onto the polishing stages, as above make sure you use a panel wipe between polish stages to give the best results!
Daytona675 is offline   Reply With Quote
Old 27-09-2016, 11:22 PM   #6
Daytona675
Also no point using a QD before polishing, just a waste of product - unless you were going to use it as a drying aid? But still pretty pointless if you are polishing afterwards.
Personally I'd go for a better LSP than Collinite after all that effort beforehand!!
Start with the 205 on a white pad first, check results - if no good move up to orange pad - if still better results required go to the 105 and so forth. Always better to start with the least aggressive polish first and work your way up. The least amount of paint removed the better!
Old 29-09-2016, 01:56 AM   #7
Justanothersept
Thank you all for the info! Sorry about the 3 bucket was meant to be 2 lol.
Old 29-09-2016, 02:01 AM   #8
Justanothersept
What would be a better LSP ?
I have a black bmw and a white nissan juke so wanted something that would be ideal for both. As they both get dirty really fast from A roads
Old 29-09-2016, 07:22 AM   #9
Daytona675
Be careful when polishing those cars! They are both going to require a completely different correction process. German paint is known for being extremely hard whilst Japanese paint is supposed to be soft. What works for the juke probably won't work for the BMW and what worked on the BMW would potentially ruin the Juke.
Better LSP - completely depends of what you're after and budget. Better durability you should be going down the sealant route, better finish look at a wax. Then you got to think about the budget! There's hundreds of threads on here looking at different LSPs
Old 29-09-2016, 09:31 AM   #10
Bilt Hamber Double Speed Wax is worth a punt for £15 (for a full size tin!) It's a "hybrid" wax so it is very durable (especially if you do two coats) but also gives a great finish. Even comes with an applicator and buffing MF
collinite, meguiars, paint correction, polish, prepare
