Old 18-11-2017, 08:35 PM   #61
CitroŽn Saxo VTS Fast Road/Track Day Project
Well you weren't kidding re the sh.. Load of photos
Been a great read and good progress you've made
VeiRoN (24-11-2017)
Old 27-12-2017, 11:11 AM   #62
VeiRoN
VeiRoN's Avatar
Boot floor in epoxy mastic and rear axle re-fitted
Quick update,refitted the rear axle,altough still needs a bit of work,to make the car mobile again and coated the rear arches and boot floor in epoxy from Bilt Hamber.
VeiRoN is offline   Reply With Quote
Old 27-12-2017, 06:01 PM   #63
ibiza55
Nice work, personally I found it didn't protect against the elements that well after a year.
Old 28-12-2017, 01:50 AM   #64
VeiRoN
VeiRoN's Avatar
Are you talking about the Epoxy? Sorry no offence but I find that very hard to believe,do post further details if you could as I'm interested.
Old 15-02-2018, 04:11 PM   #65
VeiRoN
VeiRoN's Avatar
Won't be posting any updates anytime soon as had to move garage as it has been sold,I do have a garage where I live but been forbidden to do any work on the car.
I'm currently looking for a new space to rent but it's not easy,hopefully something will come up soon as I just can't stay away from it long lul.
Meanwhile I applied ACF-50 to all exposed metal to keep it rust free while stored.
Old 15-02-2018, 05:14 PM   #66
MadOnVaux!
MadOnVaux!'s Avatar
How come?, is that some sort of clause for the house/area?
MadOnVaux! is offline   Reply With Quote
Old 15-02-2018, 05:32 PM   #67
VeiRoN
VeiRoN's Avatar
I have no idea,neighbour/s told agency I was working on my car,agency told me that's not allowed,and it's not because of the noise or anything of that nature as I've asked around,they just said I can't.
Old 15-03-2018, 02:34 PM   #68
VeiRoN
VeiRoN's Avatar
SUPERMIG150 for rust repairs and some chassis strengthening
Mainly for potholes mind you...
Back on the driver sideskirt,I've cut out all of the damaged metal that was too far gone expect this part,this below is located inside the sideskirt and the portion of it that faces down towards the outside look okay and could be saved,however had no idea how the other side towards the inside of the car was looking so bought a usb camera that connects to my phone and took some pictures,not looking very good:
Now,I could just treat it with the S-50 which is advertised as able to stop existing corrosion but I believe this is too far gone for me to confindently use this method,what is left to do is just cut out the affected metal,not easy though as access is very limited but I should be able to find a way to do it.
Made some progress on the driver inside sideskirt before moving but didn't post it,took forever due to the lack of room but with a hand saw I was able to cut out most of the rotten metal,a little bit more work needed but I think I'm most of the way there.
The Following User Says Thank You to VeiRoN For This Useful Post:
Starbuck88 (05-04-2018)
Old 29-04-2018, 03:14 PM   #69
VeiRoN
VeiRoN's Avatar
Restored the previous pictures as the domain had changed address from org to cc so had to manually change it for every 700+ pictures,also had to do this on my mobile as my pc is not working,oh well,it's all done now,until next time they mess it up again.
Anyhow,I was unbanned from working in the garage so was able to do some work on the car again.
I'm working mainly in the underneath area as I knew the front floor strengthening plates weren't doing too good and wanted to see how much the corrosion extended,more below.
Tunnel before,can't see very well from the pictures but this had some corrosion in the seams and corners,nothing too bad though as it's orignally covered by the exhaust heatshield.
Start:
So far,will get back to it later:
Been also removing the studs that aren't used and prime for the moment to prevent any rust:
After:
Onto the strengthening plates,start passenger side:
First application of the Deox gel:
Second:
Driver side,this was the worst bit,probably the worst in the whole car that remained since I've start treating it (don't mind the sideskirt all cut up,S-50 was sprayed inside,hence the color):
Again,applied the gel:
Second:
So far,I did have to cut a small bit as the metal was very thin and small pinholes started showing:
At the back of these 2 strengthening plates there were two openings,covered in underseal which I have removed,that allowed me to get the Dynax S-50 inside to protect the other side as much as I can:
Also started filling the holes in the floor same as I did with the boot section as I like it better/cleaner once everything will be painted,don't think it will need drain holes once finished like I won't be taking care of it:
I wasn't really able to get a decent photo of the after so here it is,lol.
Underneath:
Old 30-04-2018, 12:14 PM   #70
VeiRoN
VeiRoN's Avatar
Resized the gigantic pictures on the above post,apologies.
even more rust, feelsbadman, more rust, rust
