Old 16-07-2018, 04:18 PM   #1
olliewills
Recommendations for a drill attachment system
Afternoon all.
Can anyone here recommend a relatively cost-effective set of powerdrill backing plate attachment and some pads?
I need to do some restoration on a couple of cars headlights and I'm looking for something that I can use with my powerdrill. I'd obviously prefer the kit to not be too expensive as they're not likely to get a lot of use. At the same time I don't want to buy complete tat so any recommendations would be gratefully received.
I'll be going over the headlights with a few different grits first but just need something I can use with some 105/205 on the final passes to bring back the clarity.
I've looked at some of the sets on Amazon but I've no doubt that at £5-10 for the set they probably use the most rubbish foam known to man that will die after 5 minutes. I suppose perhaps I should just find a backing plate and a single good pad separately.
Cheers all
Old 16-07-2018, 04:55 PM   #2
\Rian
\Rian's Avatar
Originally Posted by olliewills View Post
Afternoon all.
Cheers all
You have answers your own question.
Get yourself a cheap backing plate as their is not alot of difference between branded and non branded.
But you wont find a good cheap foam pad for 3/4 inch backing plates, ebay do some good cheap 5/6inch ones but im gessing your going for 3inch backing plate so just pick up a good quality pad (to many to name)
Old 16-07-2018, 08:17 PM   #3
Sh1ner
The 3m headlamp kit is excellent.
If used carefully I find I can fully finish 6 to ten headlamps per kit and if you look around all the bits can be found separately.
A kit can often be found for around £18.
I cannot see the point in trying to make up something that would do as well.
