Old 11-09-2017, 01:31 AM   #51
VeiRoN
VeiRoN's Avatar
Fitted the sunroof panel:
From inside:
Applied clear silicone all round to make sure no water gets in as that would be rather annoying:
Started applying the Dynax in the interior panels as well,passenger side roof first:
Before:
After:
Took the dashboard out,will I ever remember how to get everything back in many months time? Probably not.
Just out of curiosity weighed the sound deadeniing removed at 5,5kg (will be putting some new one in though).
Dashboard brackets were looking pretty tired so put them in the Deox-C bath,before:
After:
Where the ariel is originally fitted there was some surface rust so took care of that and coated with the Electrox.
Before:
Top and clear coated the wiper arms:
While I was at it also freshened up the caliper bolts for the Brembos (the other two I was able to buy new OEM ones):
Before:
Wasn't liking the finish of the brushed Hammerite on the middle part of the rear axle (and also with time found better paints to use) so sanded that down and coated in antrachite:
Freed up some space in the engine bay,before:
The nut behind the servo was a pain to undo but got there in the end:
After:
Fender driver before:
Removed the canister bracket for ease of work,will be using two M5 rivnuts to re-install it:
The summer have killed the rest of the Electrox I had in tin form,very rubbery and a mess to apply,so sanded that down and painted with the spray instead:
After:
Primed:
Removed the bracket on the strut top passenger side as not needed and looks cleaner:
Missed some rust spots and pitted rust on the front driver arch so worked on that,before:
I've used the Hydrate 80 here prior to painting but forgot to take a picture.
Back on the rear arch I've used Hydrate-80 to treat pitted rust (was generous with the area of application) and coated with 2 coats of Electrox:
Moved the engine to free up some space so loaded it in the car,rear suspensions not too happy lol:
Before on the driver side engine bay:
After 1 application of the gel:
VeiRoN is offline   Reply With Quote
The Following 2 Users Say Thank You to VeiRoN For This Useful Post:
hoggers (11-09-2017), Sicskate (13-09-2017)
Old 11-09-2017, 06:52 AM   #52
JR1982
JR1982's Avatar
Awesome work there bud
JR1982 is online now   Reply With Quote
The Following User Says Thank You to JR1982 For This Useful Post:
VeiRoN (11-09-2017)
Old 11-09-2017, 11:01 PM   #53
wrxmania
wrxmania's Avatar
Brilliant work
The Following User Says Thank You to wrxmania For This Useful Post:
VeiRoN (12-09-2017)
Old 13-09-2017, 06:17 PM   #54
VeiRoN
VeiRoN's Avatar
Thank you,appreciate the comments.
I'm doing as much as I can without going insane as the garage I'm currently renting is up for sale and I will need to leave at some point and try to find a new one.
Back to the car,another application of the gel and not much left:
Before,scuttle panel:
It's not 100% bare metal as didn't want to go insane as already took a lot of time due to the limited space I had to sand by hand mostly.
Electrox:
The Following User Says Thank You to VeiRoN For This Useful Post:
Old 13-09-2017, 08:45 PM   #55
Magic
Magic's Avatar
Credit where it's due, you've got more patience than me! I'm going to have my 106 blasted (underside and engine bay).
Looking good though pal! You just need to get yourself a welder now.
Magic is offline   Reply With Quote
The Following User Says Thank You to Magic For This Useful Post:
VeiRoN (13-09-2017)
Old 14-09-2017, 12:43 AM   #56
VeiRoN
VeiRoN's Avatar
Probably more obsession than patience lol,blasting is a good idea though the engine bay can be done easily manually,I would hate to strip the underside with a drill lol,I will just be doing small areas where coating has failed and rust present and leave the rest as it is.
Will invest in a welder once the metal is treated,was looking at something like the Sealey MIGHTYMIG150 which seems decent for the price but haven't decided yet,supposed to be doing some welding with the course I'm attending (Motorsport level 3) so that will definetely help getting started.
Old 15-09-2017, 06:26 PM   #57
VeiRoN
VeiRoN's Avatar
Rear passenger arch before:
After a few hours (these 2 holes at the top were already present which is rather annoying):
Will use the Deox now.
Gave the rest of the arch a clean with the Surfex,it doens't look bad although would look better in black epoxy,not sure I can justify the effort tough as it will take quite some time to get all of the underseal off,might just give it a coat of the Dynax UC I don't know...
On the driver side instead decided to remove some more metal as could feel some rust behind it with my fingers:
Arch should be good now for the gel to remove the last rusty bits then I can prime it.
Top coated the bonnet brackets,will use this shade of grey for the engine bay and interior and not anthracite anymore (fake news,not final color):
Changes in shade with different lighting,for now,I like it a lot.
Seam sealed and overcoated the scuttle panel:
And on the driver fender,kinda unecessary this one but I don't care,where I see a seam I put sealer on it,also left some drain on the right should water get in it can go out.
Old 15-09-2017, 10:41 PM   #58
Mardgee
Inspirational...
Mardgee is offline   Reply With Quote
The Following User Says Thank You to Mardgee For This Useful Post:
VeiRoN (15-09-2017)
Old 22-09-2017, 09:47 PM   #59
VeiRoN
VeiRoN's Avatar
Nice paint finish Citroen.
A moment of silence for my drill that died yesterday after 1 year and 3 months of service.
Luckily still in warrant and Screwfix replaced it quickly otherwise it would have been game over for me lol.
Some progress on driver arch,start:
So far:
Treating the interior with S-50 as well,some pictures of the before.
Rear quarter driver:
Side:
Top:
Wax coming out on the other side of the seam nicely.
Rear quarter passenger:
Top:
Found some corrosion on the bottom,ground that down with 60 grit and will get treated with Hydrate-80 and then the wax:
JR1982 (22-09-2017), Sicskate (22-09-2017)
Old 18-11-2017, 09:03 PM   #60
VeiRoN
VeiRoN's Avatar
Hi,prepare for sh*tload of pictures.
Wasn't happy with all the holes in the boot area and the brush finish (kinda knew this but wanted to try anyway) so I set to rectify that,you can see below when I primed it how many holes were present:
Battery box area:
I used Isopon P40 and P38 taking care not to apply the body filler over any bare metal as wanted to avoid any surprises due to water/moisture contact,it went either on top of the fibreglass or primer.
During:
After:
Just a note,this part belows still needs work as the steel isn't flat and it is more difficult to make the surface smooth,granted this area will be hidden by the battery box so uncertain if I will address it in the future (probably will) but for now I went ahead and primed it.
Did the same process with the passenger rear arch,before:
Rear bench before:
During:
After:
Removed the spare wheel bracket as was unused and wanted to make sure no rust was lurking behind it:
B pillars before:
Rear quarter windows before:
Treated both the rear boot sections where the air vents originally are (now removed) with the S-50:
Did the same with the rear arches holes:
I made a template for the rear boot vents so they can be blanked off and no dirt gets inside:
Finishing painting these now.
So initially inspected the rear driver arch to see if I should take all of the underseal off and repaint it,looking for rust I would only find this spot:
Obliviously that escalated quickly for the sake of doing a torough job,so:
Removed the corrosion:
Why do I have Peugeot panels lol
The edge of the arch required some attention too (this part is hidden behind the VTS kit so I don't have to worry too much about color match):
Corrosion was only on the surface for the most part so didn't take much time to remove,after that it got primed:
That has been seam sealed as well but no pics for this side.
Did the same on the passenger side:
Seam sealed before being overcoated as it's more visible in pictures:
Smoothed out the passenger strut as went a bit too far with the spot weld bit lol:
Treated the roof interior with the S-50 on the driver side that I was missing,before:
Rear:
Gave a small trim down to the bumper support so I can get to the metal in the corners and treat it.
Were the metal support is installed for the sunroof sealant was used and behind it I noticed rust was developing on the bare metal,I wanted to treat it but cut the remove the sealant and some of the metal the roof bar brackets (which in the sunroof version is not installed) had to be removed:
This is how it is originally:
As you can see on the initial part I removed there is some surface corrosion present,still working on it,going to take some more time to finish all around.
Back on the bulkhead I primed the area that was clean and seam sealed one of the steering rack support and sprayed the S-50 inside:
Finshed painting the dashboard brackets:
Installed Powerflex bushes on the wishbones:
Bought a rear harnesses bar and test fitted it,not too sure about this but it has decent dimensions,42mm round bar,2mm thickness,about the same as some of the proper roll cages I've seen and this attaches to the rear seat mounts which are about 5mm thick:
Please don't mind the mess I was still working on it lol.
Quick fix on the exhaust middle section as it was all rusty and didn't want to come apart,removed all the corrosion and applied lots of copper grease to prevent that from happening again:
Well,had to go back to the axle trailing arms as I would never treat some of the rust properly and it was coming back and paint chipping off (was cheap hammerite paint which didn't use again) so I sanded down all the flaky rust with a dremel and treated the part with Hydrate-80,zinc phospate primer and solvent based enamel which is nice and tough.
Before:
Hydrate-80:
Sicskate (18-11-2017)
even more rust, feelsbadman, more rust, rust
