Old 09-09-2017, 11:53 PM   #1
euge07
euge07's Avatar
removing ceramic coating from wheels
Wasnt sure where to post this
Basically I have a ceramic coating on my wheels but i want to remove it and redo them
Now my question is given the tricky shapes round spokes etc and my polisher the smallest pads I can use are 3inch, how else would I remove the coating? Wheels are ispiri isr8
Old 10-09-2017, 12:01 AM   #2
Only way to remove a coating is abrasives. So something like Sonax EX 04-06 on a firm sponge applicator might do the trick.
If you're going to go over the top with the same thing might be worth checking with the manufacturer if there is any issue with just doing another coat on top. Could save yourself a lot of work!
euge07 (10-09-2017)
Old 10-09-2017, 06:34 AM   #3
Fentum
If you need to get into nooks and crannies, recent experience from me suggests a Dremel with a steady hand.
I used those sandpaper tubes on about half speed. Full speed shreds the tubes and seriously compromises control, leading to the possibility of gouges on the edges. Ask me how I know
The alternative on contoured surfaces is wet and dry on a rubber block. Start with a quick rub at around 500 grit to break up the surface but move to 2000 grit very quickly and work downwards to grittier paper if needed but I found 2000 worked. But be gentle and have a spritz bottle and cloth ready - the dust is fearsome!
Peter
Old 10-09-2017, 09:51 AM   #4
I definitely wouldn't be using any abrasive sand paper regardless of what grade is been used to remove a ceramic coating on any car part especially wheels
As steelaghost has mentioned why not just give them a good decon and then apply again
But if you are looking to remove what's on then decon followed by some light finishing polishing should do the trick the pads you have 3" might be difficult to get in around the spokes but will be certainly ok for the faces.
Old 10-09-2017, 10:14 AM   #5
Cookies
Cookies's Avatar
I have to agree with what the guys have said above. Do a full decon and reapply. I do this on a yearly basis on my summer & winter wheels, without any issue.
As chongo said above, stay away from sand paper. You'll only have to polish afterwards. Always choose the least aggressive approach first, and work gently from there.
Good luck.
Cooks
Old 10-09-2017, 12:49 PM   #6
euge07
euge07's Avatar
Def wouldnt be going at them with sandpaper. I will try a full decon ans claybar and reapply. Put put an extra layer on this time
Old 10-09-2017, 01:08 PM   #7
tosh
tosh's Avatar
Polish with one of these on a drill.
http://www.cleanyourcar.co.uk/index....productId=1429
Use whatever polish you would use on paint.
euge07 (10-09-2017)
