Old 11-02-2018, 11:09 PM   #1
bobby1972bobby
Menzerna
Hi all
Anyone still use menz?
I about to do my black Mercedes this week and needs doing ( last done 2yrs ago)
I intend to MF pads with a DA machine...
Ta
bobby1972bobby is offline   Reply With Quote
Old 12-02-2018, 08:14 AM   #2
rob267
rob267's Avatar
Hi. I use merzerna. I used super heavy cut 300 on a microfiber cutting pad on a audi s3 with a da.
The paint was seriously hard. Super heavy cut 300 and the pad cut very well. I refined it using a white hexlogic pad and sf3500.
I do like the merzerna range.
Decent work time and little dusting from either product.
I would recommend them.
Sent from my SM-G920F using Tapatalk
rob267 is offline   Reply With Quote
The Following User Says Thank You to rob267 For This Useful Post:
bobby1972bobby (12-02-2018)
Old 12-02-2018, 11:15 AM   #3
dg_pug106gti
I have a silver S3 and was going to use the 400 and then refine with 3 in 1 do you think that would work well on a DA or better going with your recommendation?
What pads would you also recommend for the VAG paint?
Cheers.
dg_pug106gti is offline   Reply With Quote
The Following User Says Thank You to dg_pug106gti For This Useful Post:
Old 12-02-2018, 03:23 PM   #4
TOGWT
TOGWT's Avatar
Location: Split between Hampstead, London and Ponte Vedra Beach, Florida
Selecting a suitable polish, things to consider:
http://togwt1980.blogspot.co.uk/2018/02/menzerna-range-menzerna-heavy-cut.html
TOGWT is offline   Reply With Quote
The Following User Says Thank You to TOGWT For This Useful Post:
Old 12-02-2018, 03:25 PM   #5
Leebo310
Leebo310's Avatar
I like FG400 for heavy cutting, especially on a MF pad. Other than maybe HD Cut, that's probably my heaviest combination I go for. I've used that on several VAG cars, although depends on how bad the defects are.
You'll need to refine it after if you do use FG400 or something similar, but I tend to use Rupes or Koch Chemie finishing polishes as the Menz range are a bit too oily in my opinion.
As with any machine polishing, do a test spot first and don't assume any set combination. Factor in how much time you have and the actual levels of correction you will be happy with and go from there. You may be surprised with how much correction and improvement (especially on black) you can get from a single stage medium style polish (HD Adapt on the yellow Rupes pad cuts surprisingly well, yet also finishes nicely) instead of needing to go heavy and then further refine.
Leebo310 is offline   Reply With Quote
The Following User Says Thank You to Leebo310 For This Useful Post:
