Old 16-05-2018, 08:16 PM   #1
Machuga78
How Many Pads?
How many pads do people use with their DA to remove swirl marks across a car the size of a golf whether its a single stage or 2 stage removal process? Do you clean on the fly or have say 3 or 4 clean ones sat there ready to go?
Machuga78 is offline   Reply With Quote
Old 16-05-2018, 09:04 PM   #2
wish wash
wish wash's Avatar
People will differ but for me. 6-7 pads
1 for the bonnet and front end.
2 for each side.
1 for the rear.
1 for the roof
Also, using more foam pads like this, prolongs the life of your pads. They don't heat up as much or get oversaturated. Over saturated pads don't brake the abrasives down correctly thus not giving you the results.
Old 16-05-2018, 09:14 PM   #3
garycha
I use Megs MF pads.
3x 5.5" cutting, 3 x 5.5 finishing pads,
Then 3 x 5.5 " black foam refining pads.
Ditto 3" spot pads. 3 MF cutting, 3 MF finishing, 3 foam refining pads.
All I need for Golfs, 3, 2 and single stage. I've had others, but this is core kit.
I spur pads every pass, then also wash pads as I go, then dry with Sidekick. This is quick but provides a natural break.
Old 17-05-2018, 09:12 AM   #4
Leebo310
Leebo310's Avatar
I'll clean after every pass, and then after a couple of panels swap out the pad for a new one.
On a Golf I can get away with 4 5.5in pads and then a few 3in ones.
Pretty much all of my pads I have at least 4 of, maybe 6 in some cases.
Old 17-05-2018, 09:45 AM   #5
big dave 666
If I'm doing correction work, I'll use a pad per panel. MYbe two on the roof, dependant on size. Some may think that's a little OTT but that's what I prefer to do..... And I have loads of pads also lol
big dave 666 is offline   Reply With Quote
Old 17-05-2018, 11:16 AM   #6
Berylburton
I have just finished my Boxster 981S. I used 3 x 5.5" pads and 2 x 4" spot pads. I I cleaned each pad at least once on the fly so to speak. That was the polishing stage.
I then did a Carpro Essence stage with 2 spot pads and 2 x 5.5 pads.
Berylburton is offline   Reply With Quote
Old 17-05-2018, 11:44 AM   #7
A&J
A&J's Avatar
You can have one each but youll have to clean them often so its better to have more of them. About 5 each is a good amount. You can do a lot with them before you have to clean them.
