Old 27-02-2008, 09:12 AM   #1
WHIZZER
T-Cut King (admin)
WHIZZER's Avatar
Got a question for the DW Supporters (Pros)
If you have a question for one of the DW supporters then please ask away in here and im sure one of the Studio Members will be along to answer .....
They can be found here http://www.detailingworld.co.uk/foru...ad.php?t=40246
Old 04-03-2009, 10:16 PM   #2
paulmc08
paulmc08's Avatar
Question cleaning after each polishing stage
Hi,needing a bit of advice on the machineing end of things,after each stage is it ok just to wipe off the excess with a MF or would a panel wipe or cleaner be best before the next stage,thanks in advance
paulmc08 is offline   Reply With Quote
Old 05-03-2009, 09:10 PM   #3
paulmc08
paulmc08's Avatar
Question
Hello, anyone
Old 05-03-2009, 09:14 PM   #4
dubnut71
dubnut71's Avatar
Originally Posted by paulmc08 View Post
Hello, anyone
Hi mate, this is just a sub-section that was pointing people towards the pro's, you might have more luck posting back in here:
http://www.detailingworld.co.uk/foru...splay.php?f=26
dubnut71 is offline   Reply With Quote
Old 05-03-2009, 09:20 PM   #5
Gleammachine
Gleammachine's Avatar
If you mean going from cutting to finishing polish stages then just a MF would be fine, just make sure it's soft and not likely to marr the surface, rub it on a cd to test if need be, once the panels are ready for the last step product (sealant or wax) then give a wipe down with Isopropanol to remove any oils.
Old 17-12-2009, 04:32 PM   #6
hitharder
hitharder's Avatar
Send a message via MSN to hitharder
Hi i tryed DA ing for the first time and i used my new MACallister from b and q and a combo of lime prime and menz yellow pad, i first did it on my dads renault van then on my audi A3 which is lava grey. when finished polishing and buffed off after a few minutes a kind of haze forms that messes with the light a bit like marring. what caused this as my combo isnt the most abrasive!
thanks christian
hitharder is offline   Reply With Quote
Old 17-12-2009, 05:04 PM   #7
Gleammachine
thanks christian
Sounds like buffer trails or holograms, can be caused by not working the polish for long enough, try priming up the pad first by rubbing the LP well into the pad, then take a slow approach and try not to take the speed up above 1500rpm then work thoroughly until clear, due to the slight abrasive nature of LP it sounds like it hasn't been fully broken down.
I've had issues before using LP by rotary on certain paints, if the above doesn't work then a different/dedicated finishing polish may be required.
Old 27-09-2015, 12:37 PM   #8
Coops200691
Coops200691's Avatar
Hi im struggling with a new car done loads of detailing in the past on my own and other peoples cars always had good results. I have a black bmw and cannot remove hollowgraming tried by machine and today focusing on the bonnet by hand it still will not shift any ideas ive tried assorts im using meguiars ultimate compound atm b
Coops200691 is offline   Reply With Quote
Old 29-09-2015, 10:48 AM   #9
Coops200691
Anyone
Old 29-09-2015, 11:42 AM   #10
What pads and compound do you have, you might have soft paint which will make it harder to remove the hollow grams. Is your paint jet black non metallic??
