Old 29-09-2015, 12:34 PM   #11
Coops200691
Coops200691's Avatar
Yeh its non metalic. I thought german paint was hard?? I tried with just 2 microfibres at weekend 1 for applying still no joy
Coops200691 is offline   Reply With Quote
Old 29-09-2015, 03:20 PM   #12
Your right,german paint can be hard, but jet black am assuming it is, can be soft, so what Compound&polish are you using? Also what MF pads you using( cutting, or finishing pad
Old 29-09-2015, 03:29 PM   #13
Try Meg's D300 on a MF finishing pad then finish with Meg's 205 on a finishing pad (foam)
Old 29-09-2015, 03:31 PM   #14
stanley77
stanley77's Avatar
Send a message via AIM to stanley77
I would use Lime Prime lite ideally with a machine polisher, if not microfibre cloth. For black I would do it 3 times with Dodo Lime Prime Lite and wash between stages then apply a quality wax like Purple Haze Pro.
It's all in the prep so make sure the vehicle has been clayed thoroughly.
Good luck.
J.
Here's a Jaguar that covered 114,000 miles, it was tired to say the least....
stanley77 is offline   Reply With Quote
The Following User Says Thank You to stanley77 For This Useful Post:
bigpapaburgundy (30-09-2015)
Old 30-09-2015, 01:04 PM   #15
Coops200691
Jag looks mint! Is that by machine tho? I have dodojuice lime prime just not lite?? I only have a aldi special polishers 10" cheapo but was using foam pad on it. Like i said im trying by hand now with meguiars ultimate compound is that too harsh or not harsh enough??
Old 30-09-2015, 03:03 PM   #16
Lime Prime lite has know abrasive so it will only cleanse the paint and not remove the hollow grams , you need something that has some cutting ability like Meg's D300 or Sonax perfect finish on a white Hex logic pad.
Old 02-10-2015, 08:25 AM   #17
Coops200691
What about the lime prime i already have not lite? Its almost like my paint has no clearcoat the move i try to correct it the more hollowgraming i get
Old 02-10-2015, 08:30 AM   #18
Sicskate
Sicskate's Avatar
Going to be honest here,
I don't really understand the need or point of lime prime.
If you've washed and polished a car, ipa wiped it down and protected it, what's the need to use a pre wax cleaner?
Old 02-10-2015, 08:47 AM   #19
Blackroc
Got a question for the DW Supporters (Pros)
Holograms that you are creating sounds like either -
-Technique (trying to rush)
-Dirty pads being used (the slightest contaminant will re-mark your paintwork)
-Microfibres you are using are not soft enough so are marring / swirling your paintwork
Old 02-10-2015, 08:52 AM   #20
Blackroc
In the circumstances being described above (OP still getting holograms) - LP whilst technically is a pre wax cleanser, it's nice and oily (so good for soft paints) and can correct paint a little if worked long enough due to the abrasives it contains
The Following 2 Users Say Thank You to Blackroc For This Useful Post:
Coops200691 (02-10-2015), Sicskate (02-10-2015)
