Old 05-06-2015, 10:59 AM   #11
legs
legs's Avatar
cheers guys plasterboard it is.
legs is offline   Reply With Quote
Old 05-06-2015, 03:40 PM   #12
legs
legs's Avatar
that's the wood for the stud work ordered along with the plasterboard.
going to have a busy few weeks after work now
Old 07-06-2015, 11:41 PM   #13
legs
legs's Avatar
Quick question guys, going to get this vapour barrier tomorrow, is this right?
http://www.screwfix.com/p/dmp-damp-p...-4-x-15m/22842
Am I right in saying that this goes to the wall side of the stud work?
Old 08-06-2015, 08:49 PM   #14
legs
legs's Avatar
Got this delivered today
Old 08-06-2015, 09:53 PM   #15
Gav147
Looks like you've got a busy few nights ahead!, as for the membrane I would use a breathable one (roofing felt like this one will be fine) rather than plastic DPM you linked so air can still get around.
You sure you ordered enough plasterboard?
Gav147 is offline   Reply With Quote
Old 08-06-2015, 10:00 PM   #16
legs
legs's Avatar
Yep, I'm starting to think I got too much board.
Got one wall up tonight.
Finally, how would I join that membrame or would I just layer it
Old 08-06-2015, 10:20 PM   #17
Gav147
Got a good start then, yeah just layer it starting at the bottom of the stud and lap the next length over the top so any moisture that runs down it goes with the lap. It is usually marked on the membrane for 100mm and 150mm lap.
One thing that might be worth thinking about is if you plan on hanging anything heavy on the wall, try and plan where it is going to go and put plenty of cross members in the stud work so you have some solid timber to put the fixings into. Sorry if I'm pointing out the obvious but it's easy to overlook it and then wish you had put something in afterwards.
The Following 2 Users Say Thank You to Gav147 For This Useful Post:
Farqui (09-06-2015), legs (08-06-2015)
Old 08-06-2015, 10:26 PM   #18
legs
legs's Avatar
It's only the one wall that I need to use the membrame on isn't it?
Also I'm going to use kings pan insulation on the single brick wall, would that not counteract the breath ability??
There are 4 air bricks in this wall too & air will circulate behind the wall
Old 09-06-2015, 10:05 PM   #19
legs
legs's Avatar
First wall
This wall will be further strengthened as the boiler & units will be going on here
Also started to build the stud wall panels
And the panels on the floor as it's not level
Hopefully should have all the stud work up by the end of the weekend.
Comments & advice welcome
The Following 3 Users Say Thank You to legs For This Useful Post:
Bustanut (10-06-2015), Gav147 (11-06-2015), spitandpolish (09-06-2015)
Old 11-06-2015, 04:42 PM   #20
legs
legs's Avatar
guys, does anyone have any advice regarding the what side to put the membrane on, warm or cold?
also any suggestion with regards lighting? currently have 2 double strip lights, these are bright enough, but open to suggestions
The Following User Says Thank You to legs For This Useful Post:
kiz5487 (13-07-2015)
