Go Back   Detailing World > The Homebrew Experience - A World of Shine by You- > The Alternative Moonshine Experience
The Alternative Moonshine Experience A section for all those homemade waxes, shampoo's, polishes and qd's
Old 10-12-2015, 03:27 PM   #11
Baby25
Here are a couple of pics to show the difference in beadage.
My wax:
Professional wax:
Both waxes side by side:
Baby25 is offline   Reply With Quote
Old 10-12-2015, 06:30 PM   #12
11redrex
You have three forces acting here.
Cohesion (the water sticking to itself), adhesion (the water sticking to the surface), and gravity (trying to push the bead flat).
Can't change gravity, can't change cohesion without adding something to the water, or cooling it to nearly freezing point. So the only way to change the shape of the bead is to decrease adhesion to the surface. Ie, by using a really good wax,
11redrex is offline   Reply With Quote
Old 13-12-2015, 12:43 PM   #13
Baby25
So would I be right to think that to achieve beadage of the height below, a small amount of silicone would be needed in the blend or can the 'adhesion be lowered further via natural ingredients to achieve the sort of height shown?
Old 14-12-2015, 07:10 PM   #14
11redrex
I've never tried to mix any of my own waxes, so I have no idea what you could mix successfully. I used to coat my bicycle frame and bars in WD40 before the winter, I've used graphite grease in bearings, telfon spray on hinges, and silicone grease spray on various things.
WD40 obviously wouldn't work in a wax, although I did hear that it was mostly paraffin, so.....
Graphite is probably going to be dark grey so not a lot of good,
No idea where you'd get teflon from or how you'd mix it into a wax,
Same goes for a suitable silcone.
Old 15-01-2016, 03:24 AM   #15
ashiohsiao
Hi Babyalien,
Just wondering if yo managed to find how to make the beads taller in the end? I myself am trying to figure out what helps with this aspect as well, hope you can provide me with some insight~
Much appreciated!
ashiohsiao is offline   Reply With Quote
Old 20-01-2016, 10:19 AM   #16
Baby25
No not really. Had a little play with the blend by rebalancing oils and solvent and has maybe helped a tiny bit, but could just be the placebo effect. Really not sure if it is possible without additives or not as feeling like I've pushed it as far as I can with just wax, oils and solvent though I'll keep trying as I'm a determined bugger haha.
Old 16-11-2016, 09:56 PM   #17
cargainz
hmm now that winter is setting in, is it time for me to venture into home brews... probably not but these threads make interdasting reading.
cargainz is offline   Reply With Quote
Old 18-11-2016, 03:26 AM   #18
Bod42
Bod42's Avatar
Both waxes do look good but the professional wax definitely has the edge. What is the professional wax? Maybe you can find out what ingrediants it has so you know which avenue to head towards
Bod42 is offline   Reply With Quote
Old 01-08-2017, 03:35 AM   #19
shelton
shelton's Avatar
@ Soft99 we use a specifically designed synthetic polymer for hydrophobicity, and I doubt you'll be able to beat our team of scientists with some household products or natural oils (umm, let me know if you do haha)
Your best bet is searching for commercially available polymers made for hydrophobicity, and with appropriate solubility in your solvent, and/or melting point for your equipment. Also sufficient hardness for durability.
If you can't get small enough amounts, try asking a suitable friend to order a 'sample' through their business. You might even get it for free haha
shelton is offline   Reply With Quote
The Following User Says Thank You to shelton For This Useful Post:
WHIZZER (27-09-2017)
Old 26-09-2017, 10:02 PM   #20
martec06
Try some lanolin
Sendt fra min EVA-L09 med Tapatalk
martec06 is offline   Reply With Quote
