Old 18-11-2017, 11:37 AM   #201
archiebald
Great attention to detail and with older cars there is always something to do. This'll be the mint example they use on Wheeler Dealers in ten years ������
archiebald is offline   Reply With Quote
The Following User Says Thank You to archiebald For This Useful Post:
Poobah (18-11-2017)
Old 19-11-2017, 04:15 PM   #202
fordmondeo2006
Guest
Posts: n/a
Lovely cars the UKDM integra's!
They look nicer than the JDM ones IMO
Yours is mint!!
The Following User Says Thank You to For This Useful Post:
Poobah (20-11-2017)
Old 21-11-2017, 11:03 AM   #203
Poobah
Poobah's Avatar
A little more progress last night. First up, assessment of the underside of the tank.
IMG_20171120_182157 by PoobahUK, on Flickr
IMG_20171120_182125 by PoobahUK, on Flickr
IMG_20171120_182145 by PoobahUK, on Flickr
So just a few bits of light corrosion at the edges but it'll all grind back nicely. Good news.
I also spend the evening in front the TV swapping the foam and fabric of the back seats. Tegs fade really badly across the top of the rear seats and those that have read the thread will know that I bought a set of mint unfaded seats from a JDM car to swap over. Sadly it turns out that the JDM rear seats have different mountings so this means the task at hand was to swap the foam and fabric from the JDM set onto the metal frames from my own car.
IMG_20171120_195659 by PoobahUK, on Flickr
An hour or so's work and I'd got both swapped over. the clips and fittings are a bit of a ***** to remove and refit but all pretty straight forward. Side by side shots below to show the difference between the mint set and my old faded covers.
IMG_20171120_202803 by PoobahUK, on Flickr
IMG_20171120_202721 by PoobahUK, on Flickr
Once I've got the tank and underfloor sorted (I need the seats out to get to the tank pump and sender) I'll sling them back in and see how they look.
Poobah is offline   Reply With Quote
Old 21-11-2017, 12:05 PM   #204
wish wash
wish wash's Avatar
I hope your never going to drive this car, it's far too nice now to get dirty
The Following User Says Thank You to wish wash For This Useful Post:
Poobah (21-11-2017)
Old 21-11-2017, 12:07 PM   #205
I hope you are going to drive it, it's far too nice not to!
Poobah (21-11-2017)
Old 21-11-2017, 09:30 PM   #206
Poobah
Poobah's Avatar
Ha, thanks guys. It does and will get driven. Granted only in the summer and only when it's dry but it does get exercised. Too good not to.
Old 25-11-2017, 01:47 PM   #207
Poobah
Poobah's Avatar
Tackled the underside of the tank this morning. Ground back all the corrosion and applied Hydrate 80 to the areas.
IMG_20171125_103233 by PoobahUK, on Flickr
IMG_20171125_103243 by PoobahUK, on Flickr
This is what it looks like when it's dried and gone off. Ready for primer.
IMG_20171125_122308 by PoobahUK, on Flickr
IMG_20171125_122315 by PoobahUK, on Flickr
And now all done ready for top coat.
IMG_20171125_123049 by PoobahUK, on Flickr
I also removed all the brake and fuel line brackets from above where the fuel tank was. These along with the tank straps will be getting a Deox C bath to remove any corrosion before I have them coated.
IMG_20171125_120552 by PoobahUK, on Flickr
Old 26-11-2017, 03:17 PM   #208
Poobah
Poobah's Avatar
Little bit more done today. Having decided on the top coats to use. I cracked on by applying a couple of coats of engine enamel over the Electrox I'd already laid down. I figured this would give decent protection and be pretty resistant to solvents, fuel etc.
IMG_20171126_135049 by PoobahUK, on Flickr
IMG_20171126_114202 by PoobahUK, on Flickr
Next up a couple of coats of stonechip which I figured would give a nice durable top coat.
IMG_20171126_142934 by PoobahUK, on Flickr
IMG_20171126_143027 by PoobahUK, on Flickr
IMG_20171126_142941 by PoobahUK, on Flickr
This type of job is why I love restoring cars. Start with something like below, invest a little bit of time and effort and for minimal financial outlay you've got a mint tank again. Lovely stuff.
IMG_20171111_120242 by PoobahUK, on Flickr
The Following 4 Users Say Thank You to Poobah For This Useful Post:
Disco Smudge (26-11-2017), John_H (26-11-2017), Mr Gurn (27-11-2017), steelghost (26-11-2017)
Old 26-11-2017, 06:06 PM   #209
Disco Smudge
Must be very satisfying to produce work like this
Disco Smudge is offline   Reply With Quote
The Following User Says Thank You to Disco Smudge For This Useful Post:
Poobah (27-11-2017)
Old 10-12-2017, 07:30 PM   #210
Poobah
Poobah's Avatar
Got round to doing at bit more. Started grinding out the corrosion above the tank. Grim job and nice to get it out of the way.
Here's a pic halfway through. Getting there.
IMG_20171210_132554 by PoobahUK, on Flickr
IMG_20171210_132610 by PoobahUK, on Flickr
Then I cracked on with getting the area treated with Hydrate 80
IMG_20171210_142841 by PoobahUK, on Flickr
IMG_20171210_141127 by PoobahUK, on Flickr
Here's what it looks like after it's dried.Next up is to get things masked up and lay some epoxy mastic down.
IMG_20171210_180828 by PoobahUK, on Flickr
Also got the various pipe mounts and the tank strap brackets sorted. Deox C, Electrox, Black Enamel then Black stonechip.
IMG_20171210_175736 by PoobahUK, on Flickr
IMG_20171129_182201 by PoobahUK, on Flickr
Also got this through the post. New sump. the one on mine is a bit pitted and some corrosion has set in so i'll get this prepped, re-coated and get it fitted.
IMG_20171129_182234 by PoobahUK, on Flickr
dc2, honda, integra, restoration
