Old 19-08-2017, 04:44 PM   #1
fabiolous
Need advise for a lot of products! (newbie)
Hello guys!
I have a 99 BMW 320i that did a 2-step paint correction from a professional detailer a year ago.
The car sits outside all the time, since I have no garage, and it's my daily car.
It has now lost it's protection and has some light scratches,as well as some others marks that my pressure washer hose did (shame on me, but well, still a newbie learning from my mistakes)
I want to correct the paint by myself following the rules of detailing, but don't know what set of products to buy.
I'm thinking in buying a DAS6-PRO, that's the only certainty. The decon clay/lub, compound, polish... Every product that's needed to go from 1st to last step before paint protection, don't know what to buy, even the cloths (the products are so many out there!).
Been reading about Scholl products, because of hard clearcoat that my car has, but don't know what to choose for the marks the car has.
In the end of correction process, I want to apply some ceramic coating (I leaned towards Gtecniq CSL or Gyeon, don't know yet)
Also, I have 2 scratch marks on the doors B pillar, along with some Meguiars water spot remover product stain (thought I cleaned it but now won't leave)
Regarding the chrome trim, what do you recomend? I was thinking of autosol metal polish.
Roof and trunk we're painted a month ago.
NOTE: Will probably buy all products at CYC, because I want shipping cost down to one order.
Here are some pictures:
fabiolous is offline   Reply With Quote
Old 19-08-2017, 06:05 PM   #2
matty.13
You could maybe start with scholl s20 with a white spider pad , this will get rid of most of the swirls and deeper scratches and sort your b pillars out . S20 can finish down to the lsp stage with a softer pad of your choice .
If your buying from cyc I would seal with finishkare hi temp sealant or collinte 845 .
If you are going to top with a wax I would suggest r222 or cg petes wax .
Autosol with a lot of elbow grease will be fine for you exhaust and chrome .To keep cost down you'll get away with a bottle of s20, 2 pads , and the finishkare hi temp sealant (this can also be used on alloys) 2 coats of this will give you great protection .
I would also recommend finishkare 425 detail spray .
Gyeon/g techniq are great products , I don't really like ceramic coatings too much hard work if it goes wrong .
Old 19-08-2017, 09:52 PM   #3
fabiolous
Thanks for tips.
fk1000p is already on my list, but for the wheels as you say.
I want a ceramic coating because it gives more protection and lastes longer.
Almost everyday I have issues with bird drops (damn seaguls) and also have a few spots where it attacked the clearcoat.
The main goal is to protect paint over look, because it sits outside and it's my daily car.
What about decon products? Need a claybar (don't know how abrasive) and lube. I already have kenotek wheel cleaner ultra (for iron decon).
After using S20, what surface prep should I use?
What cloth is recomendable for each step? I have a lot of microfiber towels with short pile and a gyeon WW only.
Old 20-08-2017, 10:31 AM   #4
Some suggestions (all available from CYC):
Bilt Hamber clay - a large 200g bar for not much more than some brands are charging for 100g, and it's good stuff. Probably go for the medium grade for your car. Only need water for lubrication.
Auto Finesse ObliTARate for tar removal
I would be careful with Autosol on the trims, they're not real chrome (on any car, these days) and too much polishing or use of something too aggressive can spoil them. I'd try Menzerna polishing cream for this.
I'm assuming you've got buckets, wash mitt etc?
Important MF towels - some plush ones for buffing (Eurow?), plus some shorter pile ones for removing polish residue, cleaning interiors
Always worth having an APC to hand, personally I like Bilt Hamber Surfex HD for this.
Old 20-08-2017, 12:42 PM   #5
fabiolous
Yes, I've got 2 buckets and microfiber madness incredimitt.
I use nextzett glanz shampoo to wash the car (I'll buy carChem 1900:1).
Only destiled water with the clay? I thought I'd need more lubrication (like DJ born slippy?)
About tar, I don't identify it in the paint but it's still better to use it?
The APC I have is nextzett Blitz, but what use does it have on paint correction?
Thank you very much!
Old 20-08-2017, 02:56 PM   #6
bense556
bense556's Avatar
Bilt Hamber clay only requires normal water, one of the many good things about it. As said, go for the medium grade.
You may not notice the tar, but if it sits outside constantly, then it will definitely have some, more so if used daily.
APC will allow you to attack the more stubborn areas, agitated with a detailing brush. I would also recommend getting a couple of the smaller detailing brushes for cleaning the badges/grill area.
For surface prep, after polishing wipe down with either a panel wipe, such as the one GTechniq do, for buy a bottle of IPA and mix with water in a spray bottle. This will remove any polish residue left over.
Also, get some of the masking tape for protecting areas you don't want to polish, such as rubbers, headlights etc. Makes life so much easier.
bense556 is offline   Reply With Quote
The Following User Says Thank You to bense556 For This Useful Post:
steelghost (20-08-2017)
Old 20-08-2017, 08:46 PM   #7
fabiolous
What dillution ration should I use for APC and IPA?
I got a small round "paint" brush that is very soft, is it enough for those stubborn areas?
Thaks for the tips guys, I feel less lost in the process.
Old 01-10-2017, 03:44 PM   #8
fabiolous
So, I had a few time issues but now I'm decided to go along with it and make a good winter prep.
Narrowed the list to the following products:
Start with washing and Decon:
-Snow foam: AF Avalanche or Bilt Hamber - Auto Foam?
-Shampoo: CARCHEM 1900:1 500ml or other?
-Clay: Bilt Hamber - Auto Clay Medium (200g)
-Decon: Kenotek Wheel Cleaner Ultra (Iron remover) - already have and AF ObliTARate
Polishing Stage:
-Surface prep: Bilt Hamber - Cleanser Fluid or Dodo Juice - Lime Prime?
-Polishing: Scholl S20 or other?
-Polishing Pad: Scholl Concepts - Spider Pad 140mm (white) only? (how many pads?)
-After Polishing: IPA
Protection Stage:
-Sealant: FK1000P
-Wax: top up with something? or no need to?
Thanks everybody!
Old 02-10-2017, 09:56 PM   #9
fabiolous
Anyone?
Old 02-10-2017, 10:11 PM   #10
matty.13
Sounds good.
Fk1000p 2 layers will be fine for winter.
With the s20 I would buy 2 white pads and 2 orange pads.
Reason being is you will most likely have some very fine scratches from the white pad, you will need the the orange ones to take these out . S20 is very much a pad depend product . You can use it for compounding and finishing just by changing your pad .
You should see some good results if you take your time.
I'd recommend you looks at the blit hamber product range for everything other than your polish and pads . There good honest products, priced well and do what they say .
Good luck . Post your results up when your done.
Also if you have not watched them, check out the junkman detailing videos on YouTube
choose bmw products
