Go Back   Detailing World > Manufacturers and Private Label Brands > Manufacturers and Private Label Brands > Gtechniq
Gtechniq Gtechniq was founded by quantum physicist Drew Gill in 2001, out of a total dissatisfaction with the performance of paint protection products at the time. Everything from waxes, to new-fangled polymers and PTFE based miracle treatments, nothing on the market offered any meaningful durability, either in looks, or protection. Worse still, he found that most of the products actually performed poorer than the paints they were supposed to protect. From this discontent came a simple idea, ‘To engineer the world’s most beautiful, perfectly finished, smartest and most intelligent surfaces. Surfaces that do much more than simply look great when new.’
Old 12-01-2018, 02:54 AM   #1
matt525d
Snow foam dilutions
Any idea the best dilutions for the citrus foam. I’m having issues where it don’t seem to be doing anything which isn’t right
I’m doing 1-200 in a 500ml bottle so 2.5-3 ml. Have thought about doing 50ml don’t want residue left behind
matt525d is offline   Reply With Quote
Old 12-01-2018, 10:08 AM   #2
gtechadam
gtechadam's Avatar
Hi,
We recommend approximately 1 inch of W4 in a standard 1litre sized lance, filled with warm water. We are currently working through checking all bottle labels & instructions to ensure that they are customer friendly and easy to understand. If you thoroughly rinse and follow by washing the vehicle then there shouldn't be any residue left behind
gtechadam is offline   Reply With Quote
Old 12-01-2018, 01:17 PM   #3
\Rian
\Rian's Avatar
Week
That is a very week dilution when I use FastFoam i use 100 ml of foam and 900ml of water that is a 1:9 dilution.
Is the 1:200 dilution recommended by the manufacturer if so check this is not the PIR ratio as if so you don't want that ratio in the bottle
\Rian is online now   Reply With Quote
Old 12-01-2018, 01:45 PM   #4
gtechadam
gtechadam's Avatar
1 inch is approximately 80-100ml of W4
This will produce the best results and a more 'foamy' outcome
Cleaning chemicals can still work/clean at lower ratios but the above is recommended.
The higher ratio shown is once mixed with the hose water and out of the lance
Old 12-01-2018, 01:48 PM   #5
\Rian
\Rian's Avatar
So about a 1:9 ratio, and just as I thought the other ration is the PIR (pannel impact ratio) the ration of chemical to water that leaves the lance and hits the panel.
Old 12-01-2018, 11:26 PM   #6
matt525d
So 50ml in 450 of water is 1-9 which would make more sense
Old 12-01-2018, 11:28 PM   #7
matt525d
Don’t think warm water makes any odds as it comes out ice cold due to cold water from the hose then via the lance so I’d be amazed if the temp once leaving the lance is different compared to using cold water in the bottle
Old 13-01-2018, 12:03 PM   #8
GleemSpray
GleemSpray's Avatar
I think that warm water in a lance bottle is more about helping the snow foam mix properly with the water in the bottle when you give it the initial shake - as you say, it will come out of the nozzle cold.
Old 13-01-2018, 12:58 PM   #9
Tyrefitter
Tyrefitter's Avatar
Ive been putting 300ml into a litre bottle,I use valet pro ph neutral snow foam,I’ll try it with just 100ml see how it goes.
Andy
Tyrefitter is offline   Reply With Quote
Old 13-01-2018, 02:05 PM   #10
fatdazza
So at about 1 to 9 in the foam lance, with most lances being between around 7 to 10 to one, the panel impact ratio is somewhere 70 to 90 to 1? That is a fair dilution. The concentrate must be pretty strong stuff.
