Old 30-10-2016, 10:39 AM   #1
saabfan
saabfan's Avatar
Trying to burn through paint with a rotary
At the Autoglym open day yesterday, someone asked how easy it was to burn through paint with a rotary. Autoglym tried their best. Here are the results
https://youtu.be/LyUF5X619M4
sent on my phone using tapatalk
saabfan is offline   Reply With Quote
The Following User Says Thank You to saabfan For This Useful Post:
joelk2010 (30-10-2016)
Old 30-10-2016, 11:09 AM   #2
muzzer
Moderator
muzzer's Avatar
They gave me the same demonstration i think but with a harsh cutting compound and a harsh cutting pad, it is very easy to burn through your paint. There have been numerous pictures posted over the years of people who have done just that.
Old 30-10-2016, 11:47 AM   #3
President Swirl
President Swirl's Avatar
Done it myself. Be sure to use spot-pads when correcting wet sanded headlights!
President Swirl is offline   Reply With Quote
Old 30-10-2016, 12:37 PM   #4
Gleammachine
Gleammachine's Avatar
Whilst you can burn through the clearcoat anywhere, the reality is it will be on an edge. I've had many cars come to me over the years, and nearly all that I have witnessed previous strike through's on have been on a swage line, panel edge or a common one is the parking sensor recess. Sadly this is a typical trait of the bodyshop, and due to harsh compounding after the flatting stage, and creating unnecessary sanding marks too close to the panel edges.
The Following 3 Users Say Thank You to Gleammachine For This Useful Post:
kp 115 (08-02-2017), Rodriguez (10-02-2017), X-Type_Bobstar (22-02-2017)
Old 10-02-2017, 10:49 AM   #5
phooeyman
phooeyman's Avatar
How is this corrected mate as i have a slight problem like this on a edge
phooeyman is offline   Reply With Quote
Old 10-02-2017, 01:10 PM   #6
lawrenceSA
With a repaint unfortunately
Also, there is a very big difference between burning the paint (due to excessive heat) and striking through the clear (due to removing too much paint).
And of course, how much clear was there to start with is a massive variable.
If you only have 10µ clear it will strike through much, much quicker than if there was a 100µ
lawrenceSA is offline   Reply With Quote
Old 10-02-2017, 04:25 PM   #7
phooeyman
phooeyman's Avatar
Cheers, well mine is about 20mm long on a edge Nissan...
Old 12-02-2017, 01:53 PM   #8
Slammedorion
Slammedorion's Avatar
Plastics with a foam head on a rotary can make a mess very quickly
Always catches newbies out... bubbles/ flakes off no trouble
Slammedorion is offline   Reply With Quote
Old 13-02-2017, 10:36 PM   #9
Moravcik52
Moravcik52's Avatar
I could burn through the paint on pretty much any car very quickly, even a DA.
Just use a hard pad, strong compound and hold the centre of the pad on an edge, easy peasy.
Moravcik52 is offline   Reply With Quote
