Old 14-03-2017, 09:03 PM   #1
Brick Top
Brick Top's Avatar
Scholl S20 black or S3 Gold?
Hi guys, I've recently bought a carbon black BMW e60, lovely car but covered in swirls and light scratches with the odd more moderate and deep scratch. I've already purchased orange and white hex logic pads so ideally will be using these for the correction but Im not really sure which compound so go for. I've tried poorboys ssr 2 but that isn't touching it so looking to invest in something bette and I'm torn between these 2. Can anyone offer some advice on the 2, it will be used on a daily machine.
Brick Top is offline   Reply With Quote
The Following User Says Thank You to Brick Top For This Useful Post:
steelghost (14-03-2017)
Old 14-03-2017, 09:33 PM   #2
Sawel
Can't speak for the pads as I've never used them but S3 Gold XXL has more cut and can finish down quite well with the right pad.
S20 has good cut and finishes down extremely well. Most BMW's have hard paint and IF yours does then S20 will get the job done. It won't provide the out and out cut that S3 Gold XXL has but enough to get the job done on hard paint and the finish is excellent.
The Following User Says Thank You to Sawel For This Useful Post:
Yellow Dave (15-03-2017)
Old 14-03-2017, 09:40 PM   #3
cleslie
cleslie's Avatar
I've just done my car with S20 and it cleared away light swirls easily and that was on hard VAG paint. The S3 will have more cut and remove more defects but does generally need to be followed by a finishing polish to refine.
Old 14-03-2017, 10:00 PM   #4
Radish293
Radish293's Avatar
S20. I've used S17 and S40 as a combo and also experimented with S3. S3 had a great hit but needed the two others to get a finished result. S20 will do the whole job in one go. It does need to be worked longer and will Lille need a spitz od detailing spay to work it. It's also more cost effective. If it doesn't do the trick then up it with S3.
Old 14-03-2017, 11:42 PM   #5
If you do have hard paint then I would go S3 gold on a orange cutting pad followed by S40 on the white pad or black if you want it done properly but if you are looking for just a one stepper then S20, but you might be left with some deeper scratches, it just depends what you want.
ronwash (15-03-2017)
Old 15-03-2017, 02:30 PM   #6
AndyN01
I think start with S20, if that gives you the results you're looking for then great.
If not, then follow Chongo and use S3 accepting that you'll probably need to finish afterwards.
Looking forward to the photos
Andy.
Old 15-03-2017, 09:35 PM   #7
Brick Top
Brick Top's Avatar
Thanks guys, I've ordered the s20 and will see how that goes and I'll get some pics!
I take it the claims of S3 gold being a 1 stepper by scholl a little exaggerated then?
Sent from my SM-G925F using Tapatalk
Old 15-03-2017, 09:42 PM   #8
I suspect it would only work for fairly hard paints, and the final finish would not be as clear as a "proper" two stage polish, but would be ok for a lot of people, especially​ with a wax on top to disguise any residual compounding haze.
NB never used it, just guessing
Old 15-03-2017, 10:19 PM   #9
Sawel
Not at all, it depends on the task at hand. You can use S3 XXL Gold with Scholl orange foam for a good one step finish but it won't do much if you have a lot of moderate to deep scratches.
The thing is, when people use S3 XXL Gold they're mainly using it for cut combined with a cutting pad. I normally use it with a wool pad or Scholl white spider pad for pretty heavy cut and always refine after. It's the pad that provides most of the cut and the compound complements it.
AndyN01 (16-03-2017)
Old 15-03-2017, 10:22 PM   #10
Take a look at this
https://youtu.be/FY7BehswHzs
