Old 17-03-2017, 07:32 PM   #11
Ultra
Ultra's Avatar
Originally Posted by Sawel View Post
Some of the paint jobs i see are way past saving, what you have there just needs finishing.
Old 17-03-2017, 07:36 PM   #12
Demetri
Demetri's Avatar
Great turnaround on that panel
The Following User Says Thank You to Demetri For This Useful Post:
Sawel (17-03-2017)
Old 17-03-2017, 07:42 PM   #13
lowejackson
lowejackson's Avatar
Very impressive improvement.
Not played with denim pads so can you go straight to a polish like 205 or does it need an intermediate stage?
Sawel (17-03-2017)
Old 17-03-2017, 08:43 PM   #14
Sawel
Originally Posted by stangalang View Post
I do. Ive played with them quite extensively in all honesty, in various styles, and I have to say m101 has consistently performed best. 900 to 100rpm, slow arm movements, small work areas (about shoulder width and only one or two overlaps)
I'll be placing a large order at the end of the month and m101 has been added to the shopping list.
Old 17-03-2017, 08:46 PM   #15
Sawel
Whoever did it did nothing about the heavy dust and other contamination in the paint.
So, they resprayed (or gave it to their 5 year old kid to do) and just left it without bothering about all the crap in the paint.
Old 17-03-2017, 08:47 PM   #16
Sawel
What I did was use a Scholl white spider pad and S20 to just tidy up the panel after using the carpro pad.
The Following User Says Thank You to Sawel For This Useful Post:
lowejackson (17-03-2017)
Old 17-03-2017, 09:08 PM   #17
st1965
st1965's Avatar
I got some denim pads to remove some orange peel from my st...for a first attempt i was very impressed with the carpro pads..here is a before and after pic
st1965 is offline   Reply With Quote
The Following 2 Users Say Thank You to st1965 For This Useful Post:
chongo (17-03-2017), Sawel (17-03-2017)
Old 17-03-2017, 09:49 PM   #18
Sawel
noticeable difference...
agree about the pads, will be reaching for these again and again.
st1965 (17-03-2017)
Old 17-03-2017, 10:15 PM   #19
It did pop into my mind that Scholl's compounds being DAT, that it would require more time and effort than something like you mentioned...
I'll take you up on that advice as I will be doing more orange peel levelling in future. I've read a few people mention FG400, but you prefer m101 over this?
Can these pads be use with a Rupes 15 machine and a flex 3401
Old 17-03-2017, 10:22 PM   #20
Sawel
I was doing some research on various forums like autopia and autogeek and apparently they do work to an extent on a DA like the Rupes. You'd get better results on the 3401 from what I read these pads are ideal for the rotary due to the heat generated which helps the uneven clearcoat surface level easier. They're pretty cheap the 2000 grit denim pads and 3000 velvet pads are around £5 each.
I used a 115mm hard plastic backing plate which I read help level the clearcoat better as opposed to a soft backing plate like the 3M ones.
