Old 17-03-2017, 10:31 PM   #21
Cheers mate, I would only be looking to do texture levelling, just to take the peaks down on the peel, so at that price as well it's a no brainier
Old 17-03-2017, 10:46 PM   #22
Sawel
Definitely a worthwhile purchase.
Old 17-03-2017, 11:59 PM   #23
On to it on Sunday mate, will let you know how I get on in April
Sawel (18-03-2017)
Old 18-03-2017, 12:12 AM   #24
Christian6984
Christian6984's Avatar
Great Job that, couldnt even see the reflection off the landrover in the before so thats a huge difference. Could have done with these when i had my clio mk3 it was terrible for OP
Originally Posted by Forsh View Post
You should have tried correcting it by holding the rotary 3 foot from the panel - about the same distance the sprayer was holding the spray gun
You might have got an equally crap result
LMAO
The Following User Says Thank You to Christian6984 For This Useful Post:
Sawel (18-03-2017)
Old 18-03-2017, 01:12 AM   #25
Sawel
LMAO
They're definitely worthy of the cheap price. They cake up fairly quickly but with a few pads on hand, a significant difference can be achieved.
The Following User Says Thank You to Sawel For This Useful Post:
Christian6984 (18-03-2017)
Old 18-03-2017, 07:48 AM   #26
Originally Posted by Sawel View Post
Hi all,
I had 2 hours to spare so I attacked the worst respray job on a panel I've seen and I've seen a lot!
The car in question was a 2012 Vauxhall Astra GTC. I spent 2 hours on the panel alone and I think I got around 90% improvement. If I had more time I think I could have achieved even more but I was very impressed with the job that the Carpro Denim pads did on my Flex rotary. Yes it was fairly slow going but not as slow as wet sanding.
Some before and after pics...Still can't believe how bad the respray was.
BEFORE
AFTER
Entire car machine polished - Really happy with the outcome of the affected panel above rear wheel.
Anyone else unable to see the pictures, or just me?
Old 18-03-2017, 08:40 AM   #27
stangalang
king of the flexonian
stangalang's Avatar
Can these pads be use with a Rupes 15 machine and a flex 3401
3401 is great until you hit harder paint, then a rotary is needed really. They suck on smaller throw machines like a das6 pro, I'm sure they would be more effective on a longer throw machine
Old 18-03-2017, 09:04 AM   #28
Cheers matt
It's the Dodge Challenger that has had a full respray in the states and I've already checked it last year and it's obviously covered in orange peel and swirls and the common scratches. When I took paint reading it was showing on all panels between 300-400 microns so plenty to play with but that's not the case as I want to preserve as much clear as possible but remove/flatten the paint to ensure the reflection is vastly improved.
So matt I will be useing the flex 3401 and the demin pads, so do you recommend 101 to use and any tips on using this combo would be great mate
Old 18-03-2017, 09:10 AM   #29
stangalang
stangalang's Avatar
Cheers matt
m101 everytime mick, it seems to run the longest of all the products ive tried and as its smart its a lovely even cut. Best tip is get a compressor, and at least half a dozen pads. Keep them as clean as possible and retire them way quicker than you would a normal foam pad. Gotta keep them super clean to avoid scratching
Old 18-03-2017, 10:38 AM   #30
Thanks Matt much appreciated mate. Oh and when's your next get together
