Old 17-03-2017, 08:35 PM   #1
rob warrington
Is it necessary to use both 105 and 205
Let's say you have a car with moderate swirl marks, is it always necessary to first use 105 and then go back over the car with 205 on a finishing pad?
Or is it best practice to try 205 first with a cutting pad ?
I know this is basic stuff to you guys so I apologise
Rob
rob warrington is offline   Reply With Quote
Old 17-03-2017, 08:36 PM   #2
muzzer
Moderator
muzzer's Avatar
Always always start with the least aggressive combo, so 205 on a polishing pad and check your progress. You can always go more aggressive but if you start off aggressive, then if it is too harsh you can't go back.
The Following User Says Thank You to muzzer For This Useful Post:
rob warrington (17-03-2017)
Old 17-03-2017, 08:41 PM   #3
bradleymarky
bradleymarky's Avatar
M205 should get rid of most swirls. I use an orange hex pad. I use M105 for light scratches but it can be a pain to remove so a little spritz of water helps.
bradleymarky is offline   Reply With Quote
The Following User Says Thank You to bradleymarky For This Useful Post:
Old 17-03-2017, 08:41 PM   #4
rob warrington
I guess as I tell apprentices In work measure twice cut once haha similar mentality lol can't stick it back on .
Thanks for clearing that up.
The Following User Says Thank You to rob warrington For This Useful Post:
muzzer (17-03-2017)
Old 17-03-2017, 08:52 PM   #5
lowejackson
lowejackson's Avatar
Just do a test section with 205 on a finishing pad and if that does not work try 205 on a polishing pad. If you need something stronger then try 105 on a polishing or compounding pad. Then use 205 afterwards to remove any hazing from 105 which will also increase the gloss.
Although it sounds like a bit of a faff to do this, once you know what works for your car, you just repeat the combination for every other bit of paint. It is much faster to do a test section than start off with some products you do not need plus keeping as much paint on the car is good thing
lowejackson is online now   Reply With Quote
Old 17-03-2017, 09:23 PM   #6
rob warrington
Great advice guys thank you very much
muzzer (17-03-2017)
