Old 19-03-2017, 12:09 AM   #11
Maccy44
Yeah that's the one, I wouldn't consider myself weak at all but it's hard to control! But it definitely gets very hot
Maccy44 is offline   Reply With Quote
Old 19-03-2017, 12:23 AM   #12
lowejackson
lowejackson's Avatar
The control can be learned, it is all about the angle of the machine. Lots of heat does not sound good, if the machine is new or under warranty then take it back.
Old 19-03-2017, 12:48 PM   #13
Christian6984
Christian6984's Avatar
I remember using a sealey rotary on a cousins corsa when i was between machines, they had it to hand and beat doing it by hand. Was just a case of improving the finish a bit before it went up for sale. It was a handful at first and it weighed a ton. My arms where aching at the end of the day. Dont think ill buy a rotary as my Flex 3401 is great but if i did i would look for something a lot lighter.
Maccy44 - Have a read of the guide on the first page, and start of slow speed, no heavy cutting, i found the bonnet was a good place to start being mostly flat and horizontal. dont hang around near edges or creases. When you say its getting hot, do you mean the machine or the panel on the car?
Old 20-03-2017, 11:30 PM   #14
Maccy44
The machine
However I spent a few hrs with it today, using the black pad I started to get the hang on it, it's still a very heavy machine but I feel I've started to get the nack of angles etc to stop it pulling away from me
Old 21-03-2017, 07:33 AM   #15
Dummer
Make sure you tape up all edges when using a rotary. it can do damager way quicker than you expected.
Dummer is offline   Reply With Quote
Old 21-03-2017, 10:31 PM   #16
lowejackson
Originally Posted by Maccy44 View Post
The machine
How heavy is your machine, my ageing rotary is about 2.5KG, it is possible to get lighter machines but they tend to be more expensive
Old 21-03-2017, 11:52 PM   #17
Christian6984
The machine
I seem to remember reading that there is a way you can make a rotary move either left or right or towards or away from you with a very slight twist of the angle of the machine. Was from along time ago so could be imagining it but sure someone will correct me if its not so
Old 21-03-2017, 11:54 PM   #18
Christian6984
Although i have the Flex 3401, their rotary looks quite light if i was to ever buy one. Not that i think ill need one. The 3401 isnt cheap but its a great polisher once id got used to it.
