Old 19-03-2017, 04:37 PM   #1
Dazvaleting
What comes after g3 cutting compound
Ive got some g3 cutting compound im going to use with a rotary buffer to bring back the paint on a white bodywork that has gone yellow also got some g10 my question is what do i use after do i put a polish straight on after then a wax /sealer
Dazvaleting is offline   Reply With Quote
Old 19-03-2017, 07:16 PM   #2
Luke M
Luke M's Avatar
Hey buddy. I say this with respect but I think you need to read and research the process some more. Do you have a handle on what polish is for example?
The rule you need to run with is always least aggressive first. My first thought would be does it need machining to remove the yellow? It may shift with a good decontamination. If you've tried this already and it hasn't removed it then by all means you can try machining it. The question then is do you really need to jump in with compounding, will a light polish suffice?
If you can categorically say it does need compounding then it would be that followed by a refining polish the an alcohol wipe down then you could use a sealant or wax or both. If both then it's sealant and then wax.
Hope this helps.
Luke M is offline   Reply With Quote
The Following User Says Thank You to Luke M For This Useful Post:
steelghost (20-03-2017)
Old 19-03-2017, 08:18 PM   #3
AndyA4TDI
A compound and a rotary, do you have a paint thickness gauge? This is quite aggressive. As above, very sound advice. You could be looking at primer before you know it. Try a finishing polish and a light pad first.
AndyA4TDI is offline   Reply With Quote
Old 19-03-2017, 10:07 PM   #4
Dazvaleting
What would you use to try and decontaminate thanks
Old 19-03-2017, 10:49 PM   #5
Luke M
Luke M's Avatar
Tar remover, iron fallout remover and clay.
Old 20-03-2017, 02:04 PM   #6
Dazvaleting
Thanks luke and pardon my ignorance about the polish its so confusing when your new to it i always thought polish was something for adding a shine to paint work im grasping it slowly thanks very much
Old 20-03-2017, 02:39 PM   #7
Luke M
Luke M's Avatar
It's cool buddy, I meant no offence I promise. You are actually right a polish will add shine. When I was new to it I thought polish and wax were two versions of the same thing.
