In my head (and I'm happy to be proved wrong) they all function on the same method, I've had my £20 fleebay one for over 3 years and have had no issues, I cannot see that one costing two or three times as much will be 2 or three times better.
IMO better to save that extra cash and put it towards a wax rather than a branded one which may (or may not) be exactly the same as a generic one without a sticker on it.
like I said I would be happy to be proved wrong though.
I'm not saying this shows you're wrong, but with his test method, they are a bit different.
It may be good to know that in the Mjjc lance he has a 1.1 mm nozzle and he uses a Nilfisk Pressure Washers c110
I have 2 foam lances. An expensive one that was around £60 from Autobrite Direct, roughly 9 years ago. I saw a cheap one from Direct Hoses for around £25 a few years back, after some teething problems (please don't ask lol) it has been absolutely grand. Both have performed perfectly well, and I can't honestly see where the price difference is.
The gauze needs changed in both, periodically. And when stripping down, they're almost identical.
I'd happily give the £15 one a go. What's the worst that can happen.
In my experience I would say that that Karcher snow foam lance is not great at all. The difference between it and a generic £20 effort with the brass fitting on top is considerable with the latter producing much more foam.
(that said, I don't really use the snow foam lance at all now having seen the pump sprayer light)
Whilst I like using a pump sprayer, you only need to get a faceful of prewash or TFR once or twice on a windy day before you appreciate the benefits of a lance with the oomph of a PW behind it
(aka, both tools have their place and their uses :thumb
I have the karcher attachment and when comparing pics on here or with work mates the only difference I can see is usually what product you have used?
I only bought the karcher on a sale else I would’ve opted for a £20 eBay jobbie
I only bought the karcher on a sale else I would've opted for a £20 eBay jobbie
I’m assuming they’re all the same?
Just what Halfords has off the shelf as my K2 didn’t come woth one.
But I have dodo apple ifoam, fill upto the 1st mark on the bottle and then fill the rest up with tap water, stick it on the lance and it works perfect.
I use it on ‘full blast’ btw, never turned it down to see what difference it makes
I'm assuming they're all the same?
Just what Halfords has off the shelf as my K2 didn't come woth one.
I use it on 'full blast' btw, never turned it down to see what difference it makes
I've had an unbranded £20 ebay one and paid £50 for Autobrite and both are exactly the same, both are not particularly good quality and both produce the same level of foam. The difference - losing £20 doesn't feel as bad as losing £50!
A quick look on Aliexpress shows that there are only a couple of variants of the same lance so it's probably just a rebranding exercise for the most part.
The only real difference is the AB lance is a rebranded PA lance manufactured in Italy whereas the cheaper £20 lances are made, for the most part, using the same materials, the same design and for a much lower wage bill in factories in China.
My Stihl lance is not the same as the generic brass lances. So no, they are not all the same.
94.2K members
