Going to buy my first da polisher
5K views 21 replies 8 participants last post by  Spanish_Fiesta
#1 · (Edited)
Hi there, Im just about to order this http://www.cleanyourcar.co.uk/polis...s-6-pro-meguiars-hex-logic-kit/prod_1212.html but before taking the plunge I need to know if Im making a good choice, Im a total novice when it comes to machine polishing but have done abit of reading and think this suits my needs. Is it a big deal that it cant attach a 3.5 inch backing plate ? I want to do headlights as well as my car with this. Thanks in advance
#7 ·
Hi there, Im just about to order this http://www.cleanyourcar.co.uk/polis...s-6-pro-meguiars-hex-logic-kit/prod_1212.html but ....... Is it a big deal that it cant attach a 3.5 inch backing plate ? I want to do headlights as well as my car with this. Thanks in advance
But you can fit a smaller backing plate to the DAS 6 Pro. ;)
Take your pick from the 3.1/2" or 3" ShineMate DA backing plates on the CYC site. :thumb:
http://www.cleanyourcar.co.uk/polishing/polishing-accessories/cat_15.html
Alan W
#15 ·
To clear up the confusion there is a DAS6 Pro and a DAS6 Pro Plus, which are very different machines. The Pro Plus model has the larger throw but cannot be used with a smaller backing plate. The Pro is more of a jack of all trades but therefore (relatively speaking) a master of none. The Pro Plus will cut larger areas faster and easier but is not so good on smaller or tighter areas when it’s bigger orbit and 5 inch minimum backing plate can restrict you. Both are very capable machines and neither will disappoint. In an ideal world I’d say get the Pro Plus and then add a dedicated small form factor machine at a later date, the alternative is to go for the Pro with large and small backing plates which you may then want to upgrade in the future.
#22 ·
Good choice. The advantage of a long throw machine is speed, As a novice you want to take your time and perfect your technique and enjoy the journey to a great shine.
There's a big difference between doing two cars a year or two cars a week!
Thanks for your input, It looks a good bit of kit for the price and everyone says they are great for beginners.
