Old 07-05-2018, 09:36 PM   #11
BradleyW
BradleyW's Avatar
I washed the car in the shade. Surface was cool to the touch. Not sure about residue, as I then washed the whole car with BTBM and my wash mitt. Rinsed it all off, same result. Perhaps it can strip a sealant, but not a wax?
Old 07-05-2018, 10:00 PM   #12
olliewills
Perhaps, maybe there's just something about that sealant in particular that doesn't play well with BHAF. I've had Autoglanz SynthSeal on my car without wax for quite a while in the past and never saw it's durability reduced by BHAF.
Suppose it could just be a bad batch of foam. Unlikely but that doesn't mean it can't happen.
The Following User Says Thank You to olliewills For This Useful Post:
BradleyW (08-05-2018)
Old 07-05-2018, 10:12 PM   #13
cheekymonkey
cheekymonkey's Avatar
Originally Posted by Brian1612 View Post
It isn't Rob but that doesn't mean it will strip wax. So many misconceptions with regards to PH levels. Can have two separate chemicals of the same PH level, one will kill you and the other is harmless. Same story when it comes to chemicals being used on LSPs.
in some cases this applies, but as a general rule the higher ph the stronger the product. BHAF is a strong product.
cheekymonkey is offline   Reply With Quote
The Following 2 Users Say Thank You to cheekymonkey For This Useful Post:
BradleyW (08-05-2018), Rob D 88 (08-05-2018)
Old 08-05-2018, 01:14 PM   #14
roscopervis
roscopervis's Avatar
What is the pH when it's at 4% - so 40ml Autofoam and 960ml water, for example?
The Following User Says Thank You to roscopervis For This Useful Post:
Old 08-05-2018, 02:26 PM   #15
neilmcl
Originally Posted by BradleyW View Post
I didn't allow the BH to dry. HydrO2 is very durable. I applied it to fresh clean prepared paint. The only pattern emerging is those with pump sprayers (with BH) have had an issue.
I tested the BH during the wash. I sprayed it onto a small section, worked it with the wash mitt, rinsed off. LSP had completely gone. If I spray the BH on, leave it to dwell, wash it off, it seems to strips more than half the LSP.
What "pattern", as I said earlier I've been using it for years via a pump sprayer, as many others have, and it's never degraded my LSP. Try a different wax/sealant.
Did you make sure you mixed the solution properly before use. I can imagine some just stick it in the sprayer and off they go without giving it a good shake first.
The Following User Says Thank You to neilmcl For This Useful Post:
Old 08-05-2018, 03:40 PM   #16
wish wash
wish wash's Avatar
Best thing to do is apply hyd20 again and see if the results differ. It may of been a one off, this way seems a more accurate way of seeing what's going on
The Following User Says Thank You to wish wash For This Useful Post:
Old 08-05-2018, 06:25 PM   #17
BradleyW
BradleyW's Avatar
The mixture was stated earlier. It is 40ml AF 960ml water.
There was a pattern. The use of a pump sprayer. But after more comments, the pattern is obsolete. I've washed the car and reapplied HydrO2. Time will tell folks. I don't think it's a bad batch because it's the same 5L I've been using for a while now. Unless....there is a use by date?
Old 08-05-2018, 07:37 PM   #18
neilmcl
You misunderstand me. I get you have the dilution correct but did you give your spray bottle a good shake before using, otherwise the PIR may not be totally accurate.
BradleyW (09-05-2018)
Old 08-05-2018, 08:37 PM   #19
cheekymonkey
With it being used a 4% which is alot stronger solution than most other snow foams, so compared to other snow foams its still stronger than most.
The Following User Says Thank You to cheekymonkey For This Useful Post:
Old 08-05-2018, 10:27 PM   #20
roscopervis
But what is the pH of that mixture?
Sent from my TA-1012 using Tapatalk
